Sony PS4 Pro with ADP-300CR Power Supply: STB 5V Drops, No 12V Voltage on Pins
drops206 13572 10
Why does the PS4 Pro ADP-300CR power supply have standby 5V for a moment but then shut down with no 12V output on the pins and no fan start?
Check the main startup resistors in the PSU start circuit, because the key series resistors are around 3×4.7 MΩ and 3×2.2 MΩ, so a meter with only a 2 MΩ maximum range cannot properly verify them [#16499195][#16499385][#16502979] If the meter shows no reading on that path, it indicates an open circuit [#16499385] One suggestion was also to remove the SMD resistors and test them externally in a threaded holder/socket arrangement [#16504269] The thread ends with the unit being repaired by another member, but the exact defective part is not stated [#16522468]
  • #1 16484952
    drops206
    Help: 7
    Rate: 40
    Hello. Equipment as in the subject, i.e. PS4 Pro with ADP-300CR power supply.
    STB 5V is. He loses for a second, then dead. Cooling does not start, 12V voltage does not appear on the pins. R1 and R5 resistors all. Someone already had something like that on the table?
    Spoiler:
  • #2 16499195
    michald
    Help: 210
    Rate: 437
    Check the main starter resistors.
  • #3 16499257
    drops206
    Help: 7
    Rate: 40
    I checked all resistors and it seems that they are functional except for one line on which resistors are connected in series:
    R31-4704
    R32-4704
    R70-4704
    R90-2204
    R78-2204
    R72-2204
    Unless the multimeter can't measure it.
    The path leads to a large resistor R5 and the other branch to Q2-MOV6.
    • Sony PS4 Pro with ADP-300CR Power Supply: STB 5V Drops, No 12V Voltage on Pins 2017-05-28 12.41.46.jpg (1.03 MB) You must be logged in to download this attachment.
  • #4 16499352
    michald
    Help: 210
    Rate: 437
    What is your maximum ohmmeter measuring range?
  • #5 16499365
    drops206
    Help: 7
    Rate: 40
    From what I see it is up to 2000k
  • #6 16499385
    michald
    Help: 210
    Rate: 437
    The first line of resistors is around 15Mohm
    Second 6.8Mohm
    So it's in the range of the instrument.
    No reading indicates a break.
  • #7 16499433
    drops206
    Help: 7
    Rate: 40
    Not 2204-2.2Mohm-2200kohm
    4704-4.7Mohm-4700kohm
    At least that's how he calculated the calculator
    Whereas 2701 is 2.7kohm.
    I am leg with markings.
  • #8 16502979
    michald
    Help: 210
    Rate: 437
    That's right, I made a mistake it's like a colleague drops206 wrote:
    3x2.2Mohm
    3x 4.7Mohm
    With a max. 2 Mohm instrument, you won't check these resistors
    pozdr
    Michael
  • #9 16503455
    drops206
    Help: 7
    Rate: 40
    Is there any wise head from around Warsaw that will embrace it? On Ali you can buy one after 45 USD but there is some waiting.
    Possible proposals for priv.
    The topic is still valid. When I know something more I will write.
  • #10 16504269
    michald
    Help: 210
    Rate: 437
    In place of the smd resistors, I suggest to insert this into the threaded fitter and check it.
  • #11 16522468
    drops206
    Help: 7
    Rate: 40
    A colleague robin11 put the equipment on its feet. Subject to close.
The discussion revolves around a Sony PS4 Pro experiencing issues with its ADP-300CR power supply, specifically a drop in STB 5V voltage and the absence of 12V on the pins. The user reports that the cooling does not start and suspects problems with resistors, particularly R1 and R5. Subsequent responses suggest checking the main starter resistors and measuring resistance values, with discussions about the limitations of the measuring equipment. The user also inquires about local repair options and considers purchasing a replacement power supply. A suggestion is made to replace SMD resistors with threaded fitters for testing. The topic concludes with a note that the equipment has been repaired.
