PS3 CECH-4004A: No Power, LED Off - APS-330 Power Supply, Voltage Check & Potential Solutions
marcinwrc2 7158 6
  • #1 16534639
    marcinwrc2
    the console was connected to the network all the time and the red diode was off, so I disconnected the power and reconnected it.
    It started and I started the game, after a few minutes it turned off and it does not respond to the on button at all, no LEDs are on.
    I read on the forum that this may be a problem with the power supply. So I took it apart and checked the power supply, the APS-330 sits in it.
    On a small connector with a disconnected plug there is 1-5.5V 2-0V 3-0V 4-4.6V on the pins. After connecting the plug to the board, the voltages remain, and when I disconnect the 230V mains cable and plug it back in, the measurement on the pins is 0V. I do not have a spare power supply to check the motherboard.
    Has anyone had a similar problem?
    Please help.
  • #2 16534756
    robin11
    Help: 57
    Rate: 160
    Check the power supply of the wifi module if there is no short circuit
    best regards
  • #3 16534762
    marcinwrc2
    Thanks for the answer.
    How can I check it? Can it be detached or detached?
  • #4 16537476
    robin11
    Help: 57
    Rate: 160
    Resistance meter or diode test. to the photo arrows and to the minus.
    best regards
  • #5 16539200
    szalony1
    Rate: 46
    Short-circuit test on the power supply whether it turns on
  • #6 16545193
    marcinwrc2
    Which pins to connect to make the power supply stand up?
  • #7 16645746
    marcinwrc2
    Console put into service. Replaced main board.
    You can close the topic.
The discussion revolves around a PS3 CECH-4004A console that exhibits no power and has an off LED indicator. The user reports that after disconnecting and reconnecting the power, the console briefly turns on but then shuts off and becomes unresponsive. Voltage checks on the APS-330 power supply reveal inconsistent readings, prompting inquiries about potential short circuits and testing methods. Responses suggest checking the power supply of the Wi-Fi module for shorts, using a resistance meter or diode test, and performing a short-circuit test on the power supply. Ultimately, the user resolved the issue by replacing the main board of the console.
