PlayStation 4 HDMI Issue: No Picture, Damaged Capacitor, Torn Tracks & Replacement Solution
Shroom236 6036 4
  • #1 17004306
    Shroom236
    In the subject of this post, I wrote about the Hdmi port, but it does not end there, the problem is this, one day the console hung on the cable, falling off, the Hdmi port stopped working, it looked ok, so I looked inside the console. I wanted to replace the Hdmi port, but when I got to it, I saw a damaged capacitor (on the board I marked the place where it was, it fell off) the question now is whether the lack of this element can be the cause of the lack of an image in ps4?
    Edit: it turned out that it was a missing capacitor and partially torn out tracks on the board, new tracks were introduced and everything is flying
    • PlayStation 4 HDMI Issue: No Picture, Damaged Capacitor, Torn Tracks & Replacement Solution 62E34DAC-99B7-4E6B-98E4-B3AEEC1B6759.jpeg (268.86 KB) You must be logged in to download this attachment.
  • #2 17004323
    DriverMSG
    Help: 3984
    Rate: 4883
    The capacitor must be.
    Additionally, check the transitions between the paths.
  • #3 17017067
    Robson81Malaga
    The lack of a picture may be due to the damage of the hdmi plug itself or it could have pastured the panasonic video chip. You also need to check if there is a transition on the filters. Those black cubes just below the hdmi. .even if you don't understand English well, you can see what he does and what he pays attention to. In the future I propose to emphasize the fan with a potentiometer so that ps4 does not catch the blue light of dead.youtube Andrew Paul. PlayStation 4 HDMI Issue: No Picture, Damaged Capacitor, Torn Tracks & Replacement Solution PlayStation 4 HDMI Issue: No Picture, Damaged Capacitor, Torn Tracks & Replacement Solution
  • #4 17347574
    nygys019
    Rate: 19
    Heats up a little :) Robson81Malaga I see that you know the topic, are you interested in how much it may cost to replace this chip? I have a similar problem, but surprisingly, when I connect the console via VR goggles, the image is displayed
  • #5 17361617
    Robson81Malaga
    Hello. The cost of this system is about 10- 20 euros on ebay, depending on the console model.
