Renault Thalia 1.4 - 2004 - How much does it cost to replace the seals under the
puchacz2420 13338 16
How much does it cost to replace the head gasket and other seals removed during head disassembly on a 2004 Renault Thalia 1.4 petrol engine?
The repair can fit within about 1,000 PLN, especially if the engine is the 8-valve version and the head does not need machining [#16488406] Because this engine is prone to oil leakage under the head, it is worth removing the head and checking it properly, including valve stem seals and head planning if needed [#16488415] One owner later confirmed that the same mechanic did the timing and the repair cost 1,000 PLN, after which the engine stayed dry [#16493650]
  • #1 16488190
    puchacz2420
    Rate: 42
    Hello. How much can it cost me to replace the head gasket on the Renault Thalia 1.4 gasoline engine - 2004. This, of course, involves the replacement of all seals that are subject to disassembly of the head. I have oil leak at 185,000 km and I have a new car. Can someone give me the approximate cost of the repair?
  • #2 16488406
    Daro122
    Help: 165
    Rate: 751
    After symptoms, I think that 8-valve engine, and oil leakage under the head in these engines is a typical ailment. Without planning the head, repair in the short run, in a thousand will certainly fit.
    przemek25l
    Help: 124
    Rate: 372
    With such a course and years I would give heads to do or sealants planning valves.
  • #4 16488422
    puchacz2420
    Rate: 42
    Thank you very much. The mechanic told me the same. In that case, to work. Greetings..
  • #5 16488426
    szymitsu21
    Help: 343
    Rate: 1300
    if someone does such a thing and in a thousand it fits, best regards ...
    valve bolt seals ... if someone does it for a thousand doing it I admire it
  • #6 16488505
    sly_1978
    Help: 34
    Rate: 284
    What is the timing of the EPA? I would worry more about oil and fluid.
  • #7 16488548
    puchacz2420
    Rate: 42
    A small explanation ... the timing was replaced about 2 months earlier, maybe in a thousand is located ??
  • Workshop should replace the complete timing assembly
    #8 16488586
    Daro122
    Help: 165
    Rate: 751
    Szymitsu21's colleague means responsibility for the work done, so according to the court battles, the workshop should do everything it is necessary not to expose the client to losses, in this case it should replace the complete timing. It doesn't matter that he was replaced two weeks ago. If something goes wrong and the case is based on a court, the workshop will bear all the costs associated with it. It doesn't matter that he didn't want to shave you, then you say you weren't aware and the workshop can't say that.
    #9 16488675
    sly_1978
    Help: 34
    Rate: 284
    Can you give some example?
  • Workshop should replace the full timing set for liability
    #10 16488711
    szymitsu21
    Help: 343
    Rate: 1300
    And everything about ...
    And an example? someone puts to me before the timing I will make the heads and then in a month the tensioner pin will come out, and I will not tell the customer that it is the fault of the predecessor because it makes me laugh ,,, That is why everything is done according to art which unfortunately costs.
  • Timing belt should be replaced during head repair
    #11 16488946
    sly_1978
    Help: 34
    Rate: 284
    And every time you repair the head, you install a new timing gear, as when, for example, replacing the gearbox, you install a new clutch? Let's not go crazy.
  • #12 16489053
    Daro122
    Help: 165
    Rate: 751
    sly_1978 how we do each of us knows, everyone is doing fine, for 30 years of work I jumped out of the cash register once.
  • #13 16489170
    szymitsu21
    Help: 343
    Rate: 1300
    Let's not go to extremes, I'm talking about a situation in which another workshop did it and I'm not sure when.
  • #14 16490863
    Stefan_2000
    Help: 36
    Rate: 39
    So moral for the future, repair the car in one workshop, because then we will save on preventive replacements of almost new parts and there will be no one to blame if something goes wrong?
    :arrow: szymitsu21
    How would you change the timing two months ago, would you also replace it now?
  • #15 16490968
    psooya
    Help: 376
    Rate: 575
    Still pay VAT and income taxes, subtract parts, liquid and oil and you can earn PLN 300 or less. If you have no costs, it is poor and if you rent premises you will not eat. The market is broken. You can keep clean and pour old liquid or oil but it makes no sense.
    Gentlemen on crusaders with their own barns in the villages not paying taxes fit the market and then everywhere is too expensive.
  • #16 16491146
    szymitsu21
    Help: 343
    Rate: 1300
    I'm talking about it.
    And to my predecessor, if I did it not long ago I would put on a new belt.
  • #17 16493650
    puchacz2420
    Rate: 42
    Thanks a lot. now I know what's going on with these repairs .. The timing was done by the same mechanic so it was worth 1000 zlotys. Dry engine and calm for now. It was the first glitch since the news interesting what will come out .. Thanks for help. pozdr
The discussion revolves around the cost and considerations for replacing the head gasket and associated seals on a 2004 Renault Thalia 1.4 gasoline engine, particularly in the context of an oil leak at 185,000 km. Participants suggest that oil leakage under the head is a common issue for this engine type. Estimates for the repair cost range around 1000 PLN, although some emphasize the importance of also planning the valves and potentially replacing the timing gear to avoid future complications. The consensus is that repairs should be conducted by a single workshop to ensure accountability and quality of work.
