Renault Espace 2.2 dci: Valve Seal Replacement, Camshaft Mounting & Head Regeneration Costs
M-A-T-E-U-S-Z 6399 19
How much should it cost to regenerate the cylinder head and repair the worn camshaft mounting surfaces on a Renault Espace 2.2 dCi?
A reasonable price for this kind of head regeneration seems to be about 1000–1200 PLN, with some cases ending around 1100 PLN [#16309073][#16309050][#16311072] One user reported a very favorable quote of 450 PLN for labor plus 40 PLN for seals and his own guides, but others said that looked unusually cheap for a full head job [#16310812][#16311984] Another poster estimated that a full repair of these engines can reach about 4000 PLN when more is needed than just gasket replacement and planing [#16309393] For comparison, a new head was said to cost about 2000 PLN on a 1.5 dCi, so repair was described as roughly half that [#16310371]
  • #1 16308327
    M-A-T-E-U-S-Z
    Rate: 57
    Hello. I bought an espace that kicked like a locomotive, after dismantling and taking off the head the valve seals are clearly to be replaced, but this is not a big problem. I am worried that the camshaft mountings together with the feet and the rollers have large scratches as if someone did not change oil in their life. Someone knows the cost of head regeneration, i.e. replacement of guides, valve and seat grinding, planning, replacement of sealants and handling of these scratches. What will the reasonable price be for such a job so that they do not tear me down at the plant. Renault Espace 2.2 dci: Valve Seal Replacement, Camshaft Mounting & Head Regeneration Costs
  • #2 16308598
    waniaolo
    50 PLN. from hole X 16
    And planning, PLN 50-70
  • #3 16309050
    marekwodniak
    Help: 14
    Rate: 194
    I did it but in 1.5 dci with camshaft replacement. PLN 1,100.
  • #4 16309073
    diesel022782
    Help: 13
    Rate: 116
    hello buddy such a head 1000 to 1200 for such work, it depends on the price of parts and how much scatter in wear
  • #5 16309165
    jenusz11
    Help: 33
    Rate: 196
    did you look at the turbine? I doubt diesel smokes through the valve seals
  • #6 16309278
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Buddy, pull the bowl and see the oil pump chain, then unscrew the pump and check that there are no mega slack.
    How is the exchange.
    The mountain is a pick.
    You can also check the acetabulars.
  • #7 16309303
    grzegorz22lowicz
    I am also replacing the gasket under the head myself, by the way, the head is being lapped, replacement of sealants etc. My costs are ridiculous because I only pay for parts, the whole head will cost me around PLN 450. Tell me how much this E3 has traveled because looking at the picture. it's actually as if someone would not change the oil and how can I advise something, watch out for the threads fixing the injections, I personally converted them to 8 because it was half that was org.6 and half was already 7. And as for this, he kicked like a dragon It does not have to be a turbo My E3 has over 280 thousand regular oil, the turbo spec looked at the turbine and said that it is not in bad condition, these cars are very sensitive to oil! And when it comes to colleague jenusz11 you are wrong because the car can smoke like a T-55 tank when starting just through the valve sealant!
  • #8 16309323
    jenusz11
    Help: 33
    Rate: 196
    exactly like that at the start of the sea to smoke but rather not while driving, if the turbine was eliminated, I would also exchange rings for peace of mind and acetabulum
  • #9 16309346
    grzegorz22lowicz
    well, what are the costs of the renovation?
  • #10 16309393
    Help: 1405
    Rate: 6430
    The repair of these engines costs about 4000 PLN.
  • #11 16309479
    M-A-T-E-U-S-Z
    Rate: 57
    I have already ordered crankshafts, rings, valve seals, guides, seals and the rest of the duplicates. As for the regeneration of the head is a bit expensive.
  • #12 16309508
    Help: 1405
    Rate: 6430
    Do this pump because you will crash if you have such a trash in the engine.
  • #13 16310371
    marekwodniak
    Help: 14
    Rate: 194
    There is a cost to renovate the head because it is not replacing the gasket and planning. See how much the new head costs. Up to 1.5 dci PLN 2 thousand. Repair is half.
  • #14 16310557
    M-A-T-E-U-S-Z
    Rate: 57
    I have already found a guest what this head will do for me at a very favorable price.
  • #15 16310693
    diesel022782
    Help: 13
    Rate: 116
    what price?
  • #16 16310812
    M-A-T-E-U-S-Z
    Rate: 57
    labor 450 PLN together with its guides plus my sealants 40 PLN
  • #17 16310890
    diesel022782
    Help: 13
    Rate: 116
    do you need to fight and pan? such features?
  • #18 16311072
    marekwodniak
    Help: 14
    Rate: 194
    For me it started at 400 zlotys and ended at 1100. Someone did not change oil.
  • #19 16311929
    Help: 1405
    Rate: 6430
    marekwodniak wrote:
    Some guy didn't change oil.
    And others like him urge people to stop oil changes, there is a lot of it on Youtube.
    Maybe they saw the scribble and believed it.
  • #20 16311984
    diesel022782
    Help: 13
    Rate: 116
    this is what I mean, I can't imagine making this head for 450 zlotys well, but other engine machining specialists are also my opinion.
The discussion revolves around the replacement of valve seals, camshaft mountings, and head regeneration costs for the Renault Espace 2.2 dci. Users share their experiences and costs associated with similar repairs, indicating that head regeneration can range from PLN 450 to PLN 4,000 depending on the extent of damage and parts required. Specific tasks mentioned include replacing guides, valve and seat grinding, and planning. Concerns about oil maintenance and its impact on engine performance are also highlighted, with suggestions to inspect the oil pump and turbine. Overall, the conversation emphasizes the importance of regular oil changes to prevent severe engine issues.
