Peugeot Partner 2007 1.6HDi: Increasing Oil Consumption after Head Repair - Change to 10w40?
basilowsky 20193 14
How can I stop a Peugeot Partner 1.6 HDi from consuming about 1 liter of oil per 1000 km after head repair, and will switching to thicker 10W40 oil help?
No, changing to thicker oil is unlikely to solve this; the thread points to an internal fault after the head repair rather than the oil grade. One reply suggests the valve stem seals may have been installed incorrectly [#16489258] Others note that oil in a turbodiesel usually comes from the turbo, cylinder liners/rings, or valve guides, so those areas need checking instead of just changing oil viscosity [#16489666] The later compression test on cylinder 2 showed 22 bar, rising to 35 bar after the oil test, which strongly suggests worn rings on that piston, and the blue smoke after a cold start fits that diagnosis [#16592148] A mechanic in the thread also said that 1 liter per 1000 km and a pressure drop means a repair is waiting, and reported a similar case fixed by replacing rings and seals [#16593677]
  • Oil consumption likely from turbo or crankcase breather
    #1 16488538
    basilowsky
    Hello, Peugeot Partner 2007 engine 1.6HDi 90km DV6ATED4 (without fap, without variable geometry, without dual heads) mileage on the top 220000km, pour Castrol oil 5W40 - this was poured from the news. A year ago I gave the head for renovation. Replacement valve seals, stems and milled seats. The engine did not take anything oil before repair. Since that repair I have to add about 1 liter of oil per 1000km. Injection was pulled out a month ago. The pump said that all 4 were in good condition, but the first injection from the timing was all in oil / nagaga, the remaining 3 dry and clean. I have to change the oil (I change every 10,000km) and I would like to flood it more thickly. Please advise whether it is worth it in this situation. I will add that the engine has no external oil leaks. Intake pipes, intercooler, throttle and intake slightly oily. There is also some oil pouring from pneumothorax, but not so much. greetings
  • #2 16488620
    Daro122
    Help: 165
    Rate: 751
    This engine should run on 5w30, if after repair began to take oil then you do not need much sharpness to tell what is the cause.
  • Oil consumption likely from worn first injector seal or rings
    #3 16488692
    sly_1978
    Help: 34
    Rate: 284
    Which was the reason for disassembly of the head.
  • #4 16489209
    basilowsky
    The head was removed due to 3 broken glow plugs and a lot of carbon deposit in the intake manifold and inlet channels in the head. The head went to an ultrasonic cleaner. Before the repair without practically 3 glow plugs, the engine burned at -15 without a problem at night, but it telepped terribly. The question is, after sealing the head, is it possible for the "bottom" to run and burn the oil through the rings on 1 piston? If so, I wonder if pouring thicker oil can help?
  • #5 16489223
    ociz
    Help: 1379
    Rate: 3486
    Pouring inferior oil always only helps traders, because you will finish the engine faster.
  • #6 16489258
    moto-kord
    Help: 137
    Rate: 505
    basilowsky wrote:
    Hello, These valve seals, stems and milled seats. greetings
    Hello, badly installed valve sealers.
  • #7 16489494
    basilowsky
    Hello, can pouring thicker oil a little help? Can this engine fly on 10w40?
  • #8 16489510
    Daro122
    Help: 165
    Rate: 751
    Filling a thicker oil will definitely help with faster compressor turbo consumption the "worst" oil you can pour here is 5W30.
  • #9 16489666
    robokop
    Help: 1763
    Rate: 6372
    Do not change the oil, because it will not help in any way. Turbodiesel can consume oil in 3 ways - the most common is not a tight turbocharger, followed by cylinder liners, valve guides at the end.
  • #10 16489784
    basilowsky
    And what do you think is an oily injector on 1 cylinder? The part of the injector that sits in the head was all covered with a black liquid substance - like oil. The others were very clean. I will add that not even a drop of carbon deposit is filtered through the injector seals. Everything is tight outside.
  • #11 16490398
    milejow
    Help: 1563
    Rate: 5149
    basilowsky wrote:
    which sits in the head was covered with a black liquid substance - like oil
    Released a copper washer sealing the injection in the head
    Działalność własna
    Mętów 99, Lublin, 20-388
  • Low compression on cylinder 2 points to ring blow-by
    #12 16592148
    basilowsky
    Hello. I return to the topic of my engine. Turbine after regeneration. Before repair, it drained oil onto the intercooler, after repair the entire intake from turbo to throttle was dry. Another thing was the compression pressure on a warm engine. Counting the timing cylinders: No. 1-30bar, No. 2-22bar (after oil test 35bar), No. 3-30bar, No. 4-31bar. My question: is it possible for the engine to pass 1 liter of oil per 1000km through the rings on the second piston? Or maybe this amount of oil can only escape through the valve sealers? I will add that the car has power, in the morning after firing nothing to kick off, but on a cold after driving a few dozen meters around 2000ob it releases a blue cloud of smoke. This is the case every time after a long stop. The car kicks in gray at the shoe above 3700 revolutions. Thanks for all the answers.
  • #13 16593677
    Daro122
    Help: 165
    Rate: 751
    1 liter of oil for 1000km - in addition, there is a lot of pressure drop, expense waiting for you. I am freshly replaced after replacing the rings and sealants and so far it is good.
  • #14 16596561
    basilowsky
    Daro122 how much did this repair cost you? Did you give the car to someone or did you make it yourself? Did you also take oil before renovation?
  • #15 16597572
    Daro122
    Help: 165
    Rate: 751
    I do such repairs every day, I have wholesale access to parts, so it was not expensive for me, but for the customer if the repair without surprises a little over two thousand.
The discussion revolves around a 2007 Peugeot Partner with a 1.6HDi engine experiencing increased oil consumption after a head repair. The owner reports needing to add approximately 1 liter of oil per 1000 km, a significant change from before the repair. Various responses suggest potential causes, including improperly installed valve seals, issues with the turbocharger, or cylinder wear. The owner inquires about switching to thicker oil (10W40) to mitigate the oil consumption issue. Responses indicate that using thicker oil may not resolve the underlying problems and could potentially worsen engine wear. The discussion also touches on the condition of the injectors and compression readings, with some suggesting that oil consumption could be linked to the second piston rings or valve sealers.
