GoClever Navio 520 Lifetime Map Update: Stuck on 2014.12 European Package for 2 Years
stan-50 7335 6
  • #1 16542369
    stan-50
    When I bought the navigation, the description said it was a "lifetime map update" package.
    According to the update instructions, I easily go to the map page.
    The problem is that a map package dated 2014.12 has been hanging there all the time for 2 years
    There is no newer map for not a single European country (including Poland of course).
    Do any of you know what is going on and did it? I am already thinking about buying a license for AutoMapa, because it is annoying that so many new roads, expressways were built, many streets in cities were rebuilt, new roundabouts were created, some streets are one-way - so the map two years ago ceased to be useful.
    Best wishes
    (The device has Mireo Don't Panic application loaded, ver. 4.7.5 under Windows CE)
  • #2 16542812
    koala106
    Help: 471
    Rate: 1240
    A common situation - a lifetime update is often a mockery as you read the license terms.
  • #3 16542890
    Freddy
    Help: 1394
    Rate: 2822
    This is the basis for cash back for equipment as a breach of contract :)
  • #4 16542973
    koala106
    Help: 471
    Rate: 1240
    For other manufacturers, a lifetime warranty = until the end of the product's production. A literal interpretation can be confusing.
  • #5 16543038
    Freddy
    Help: 1394
    Rate: 2822
    Very often, the "lifelong update" option requires certain conditions to be met, e.g. registration within a specific period.
  • #6 16543114
    jajacekpl
    Help: 65
    Rate: 268
    The easiest way - write to the GC website, they will explain everything to you
  • #7 16544855
    stan-50
    Thank you.
    It brightened up. Greetings to all.
    PS. I received a reply from GC: "This model does not have a lifetime update".
    So the question is: Why can I log in to the update server? (Rhetorical)
The discussion revolves around the GoClever Navio 520 navigation device, which was advertised with a "lifetime map update" feature. The user reports being stuck with a map package dated 2014.12 for two years, with no updates available for any European countries, including Poland. Responses highlight that "lifetime updates" can often be misleading, as they may only apply until the product's production ends or require specific conditions for activation. The user received a response from GoClever stating that their model does not actually support lifetime updates, raising questions about access to the update server. The user is considering purchasing a license for AutoMapa due to the outdated maps.
