[Solved] Is it possible to upload android 7 to a Samsung Galaxy Tab 4 7.0 sm-t230 tablet?
Dawidoxxxxv 58041 4
  • #1 17003890
    Dawidoxxxxv
    Rate: 11
    Hey
    I have a Samsung Galaxy Tab 4 7.0 sm-t230 tablet. I would like to upload a newer android. The question is, is it possible and how?
    moher40
    Rate: 27
    1. root
    2. ADB + FASTBOOT
    3. Custom ROM such as AOKP or CM or something stock, if it turned out to be this model.
    gradek83
    Help: 930
    Rate: 2103
    Android is not just windows, another system that can be upgraded as soon as a newer version comes out, it is rather a more complex process. If the manufacturer has not updated the software, then at best, as a colleague wrote above, you can count on a Custom ROM.
    Unless I'm mistaken, the last one update 2015 is android version 4.4.2
    Instead of android 7 you can look for Lollipop 5.1
    Remember, whatever you upload, you do everything at your own risk.
    moher40
    Rate: 27
    Or CM, but ... honestly I have always had problems with CM. The AOKP worked best for me. When they did something, they did it well and CM did endless projects, but it was in the heyday of the HTC Wildfire S and it could change something for 5 or 6 years in CM. However, it is worth reading:
    https://forum.xda-developers.com/tab-4/development/sm-t230-nu-unofficial-cm-11-based-t3648887
    Here, a friend will find practically everything that was invented on the sm-t230:
  • #5 17077489
    Dawidoxxxxv
    Rate: 11
    Thanks, I'm closing.
