Upgrading Samsung Galaxy s6 from Android 5.0.2 Lollipop to 7.0 Nougat: How To?
daroz078 3852 9
How can I check whether my Samsung Galaxy S6 can be updated from Android 5.0.2 directly to 7.0 Nougat, and should I wait for the OTA message or update now?
You can check available firmware with SamFirm by entering your exact model, for example G920F, instead of relying only on the phone’s OTA prompt [#16344410][#16346599] For the G920F, a 7.0 build exists in the XEF region, and it is multi-region, so it should also work for Poland [#16346599] At the time of the thread, Nougat was still available only in some countries and Vodafone-branded variants, so you may have to wait for the OTA rollout [#16344333] Updating to 6.0/6.0.1 first is also safe and “nothing will happen” to the phone; it was recommended as a worthwhile intermediate update [#16344333][#16344410]
  • Checking Galaxy S6 update availability before installing it
    #1 16344176
    daroz078
    Rate: 47
    Hello! I have a Samsung Galaxy s6 version 5.0.2 Lollipop. The smartphone is not branded, bought on the free market. Well, I would like to upgrade to version 7.0 Nougat. The only question is whether I could check in the phone if there is a possibility of updating? So far, from time to time I have received messages with the possibility of upgrading to version 6.0 Marshmallow but I rejected them because I do not want this version. In the tel settings, I tried the manual update and started to download updates weighing about 1400mb, there was no message what these updates were so I turned off because I would not like to update the phone to version 6.0. Please help me, how can I check if it is possible to update to 7.0? Maybe it's better to wait when the message comes by itself? greetings :lol:
    makosuu
    Help: 369
    Rate: 370
    Wait for updates, in the meantime you can update to 6.0 nothing will happen to you. For now it is only in other countries with the Vodafone brand.
    beo
    Level 37  
    Help: 298
    Rate: 238
    Check for updates with SamFirm. It will search for a 3rd or 4th file driver - this is the best way to update. MM is in version 6.0.1, i.e. after corrections to +, in particular there is an improvement in terms of battery, so I think it is worth replacing the older lollipop with 6.
    • SamFirm.rar (3.69 MB) You must be logged in to download this attachment.
  • #4 16345137
    daroz078
    Rate: 47
    I updated to version 6.0.1 and everything went OK. Even my settings from the previous version were saved. A more pleasant look that feels like the smartphone is bigger. It's also cool to play with what I have until the update to 7.0 comes. Thanks for the helpful tips. greetings :lol:
    beo
    Level 37  
    Help: 298
    Rate: 238
    Did you update via OTA, or did you upload Odinem rom downloaded by SamFirm? Because if you are updating via OTA, it's worth doing wipe data.
  • #6 16346352
    daroz078
    Rate: 47
    Sorry but I have no idea what OTA or Odin is :D I downloaded the same SamFirm what you entered but it is probably damaged or something because it does not go to unpack it.
    I made the update to version 6 manually from the options in tel.
    And I don't know what wipe data is all about :lol:
    beo
    Level 37  
    Help: 298
    Rate: 238
    Annex corrected. In the model field enter, for example, G920F - if you have one. For this model it is 7.0, for France, but it has our XEO region, so everything will be ok. As for Odin, I refer here: http://forum.android.com.pl/topic/101567-odin-flashowanie- Koreinalnych-romów- samsunga-za-using-odina / As for the S6 is: http://forum.android.com.pl/forum/1408-rom-y-m modifiedacje/ there you have the description of SamFirm etc. As for the update to 7.0 itself: http://forum.android.com.pl/topic/311616-n-70-pda-g920fxxu5eqac-xef/?page=25#comment-5029432
  • #8 16358462
    daroz078
    Rate: 47
    Thanks. I will try to explore these secrets of knowledge. The question is when I would expect it to be updated. to version 7? :lol:
  • #9 16358485
    beo
    Level 37  
    Help: 298
    Rate: 238
    For G920F there is 7.0 XEF Region, but it's multi so it's also for Poland.
  • #10 16708203
    daroz078
    Rate: 47
    Thanks for the help. greetings :)
The discussion revolves around upgrading a Samsung Galaxy S6 from Android 5.0.2 Lollipop to 7.0 Nougat. The user inquires about checking for update availability, expressing reluctance to upgrade to 6.0 Marshmallow. Responses suggest waiting for official updates while also recommending the option to upgrade to 6.0, which has benefits like improved battery performance. Tools like SamFirm and Odin are mentioned for manual updates, with specific instructions on entering model numbers for compatibility. The user successfully upgraded to 6.0.1 and seeks further guidance on the timeline for the Nougat update.
