Corel DRAW 2017: Saving a Project in X5 Format - Compatibility with Older Versions
BarakusPiEl 6672 2
  • #1 16491217
    BarakusPiEl
    Hello, I am a beginner so if I wrote something wrong, please move it ;)
    So this is how I have CorelDRAW 2017 version and in this version I also have a "project" unfortunately it has to be saved in X5 version. I am green at this, so please help, it is a very urgent matter.
    It is possible to use older versions but only up to 11: /
  • #2 16491294
    REMUR.
    Help: 143
    Rate: 255
    Save to version 15.0, powered by X5
  • #3 18856958
    s113
    Rate: 30
    In general, the Corel to 12 is flying, the above works like a coal car, so I am at work, a smart computer scientist, installed X7 and here it made everything worse.
    Saving "Save AS" to version 12 crashed when opening in Corel 12.
    I found this way because ole works.
    I open files in X7 and open pure Corel 12. In Corel X7 I select and copy CTRL + C to the memory buffer.
    I'm going to Corel 12 and doing CTRL + V and pasting from the memory buffer. And so page after page.
    Then in Corel 12, when I write it down, it works.
