Invisible Thumbnails for .CDR Files: CorelDRAW X3, Windows 64-bit Ultimate Reinstall Issues
pytlowany1 9753 7
  • #1 17161642
    pytlowany1
    Rate: 90
    Hello. After reinstalling Windows 64-bit Ultimate, the system does not see thumbnails of .cdr files
    I have CorelDRAW X3. Yesterday I uninstalled the program and reinstalled and the thumbnails were visible, but today after turning on the computer, unfortunately still the same: /
  • #2 17161653
    JuniorS
    Help: 125
    Rate: 195
    Check if the checkbox in Folder Options > View > Always show icons, never thumbnails.
    Or ... CDR and CPT files are usually of Corel origin. As of Corel's X5 version the problem shouldn't appear. If you do not have CORELA installed above version 5, do so and the problem will disappear
    install CorelDRAW version X5 and the problem will be gone
  • #3 17161713
    pytlowany1
    Rate: 90
    This is how he is decorated ...
    Cholerka fits me X3 because I have legal ;-)
  • #4 17161741
    JuniorS
    Help: 125
    Rate: 195
    As I remember I used to struggle with it and had a problem with pdf thumbnails. Pdf-and I failed because I didn't really need these thumbnails. And as for the CDRs, I did not come up with anything in the X3. I fought like a lion, fell like a fly ... and installed the X5. It was like salvation ;) The problem solved itself
  • #5 17161783
    pytlowany1
    Rate: 90
    JuniorS I consider your options final - maybe someone else will advise you.
  • #7 17527333
    pytlowany1
    Rate: 90
    Thanks, but I don't know what's going on ;-)
    The most important thing is that when I press Open in Corel and a given folder, I see a preview of the files - that's enough for me. best regards
  • #8 17527461
    resztki
    Rate: 20
    After all, there is an answer in the link. Uninstall from "Programs and Features" a program named "Corel Graphics - Windows Shell Exstension" and reinstall it. The installer is located in the folder "Files (x86) \ Corel \ CorelDRAW Graphics Suite X5 \ Setup \ CGS15". helps 100%.
The discussion revolves around the issue of missing thumbnails for .cdr files after reinstalling Windows 64-bit Ultimate and using CorelDRAW X3. Users suggest checking the Folder Options to ensure that "Always show icons, never thumbnails" is unchecked. It is noted that upgrading to CorelDRAW X5 resolves the thumbnail visibility issue, as users who faced similar problems found success after installing this newer version. Additionally, uninstalling the "Corel Graphics - Windows Shell Extension" and reinstalling it from the CorelDRAW X5 setup folder is recommended as a solution. Some users express satisfaction with being able to preview files within CorelDRAW despite the thumbnail issue.
