[Solved] WIN XP SP3 Update Issue: Kernel32.dll Error in Word & Excel - Fixing GetDataFormatEx Procedure
CYRUS2 16830 11
How can I fix Word and Excel not starting after an automatic Windows XP update, when the error says there is no GetDataFormatEx procedure in Kernel32.dll?
Uninstall the recent Office update KB4461522, which is identified as the likely cause of the “no GetDataFormatEx procedure in the Kernel32.dll library” error on XP systems with Office 2010 [#17563276][#17563092] One reply also mentioned KB2863821 together with KB4461522, but concluded that KB4461522 was the culprit [#17563092] If you are not sure what changed, open update history or Add/Remove Programs and show updates, then remove the most recent update(s) [#17560188][#17559779] After removing KB4461522, Word and Excel should work again [#17563276]
  • #1 17559765
    CYRUS2
    Help: 1241
    Rate: 3530
    Today was an automatic update of WIN XP.
    After this update, I can not start Word and Excel.
    Corel works.
    Firefox and internet work
    A message appears: no GetDataFormatEx procedure in the Kernel32.dll library
    The system is not adapted to these applications.
    How to fix it ?
    I have an original XP CD delivered with XP.
  • #2 17559779
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    There is no update for XP unless you have buried the registry.
    Uninstall any updates that have been installed.
  • #3 17559904
    CYRUS2
    Help: 1241
    Rate: 3530
    They send them from time to time.
    I do not bury in the registers because:
    1. I do not know about it
    2. The XP system works "super" and does not even need it.
  • #4 17559917
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    There is not, the last one was probably in 2017.
    What exactly did you install?
  • #5 17559987
    CYRUS2
    Help: 1241
    Rate: 3530
    Write how to fix it.
    Does this install office 2010 or windows XP?
  • #6 17560058
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    You can not communicate with you! You can not write what has been installed, I wrote that you have uninstalled the updates, you have not written anything about it.
    > Does it install office 2010 or windows XP?
    I do not know what you mean, you already have Office and XP installed, so what are you writing about?
  • #7 17560167
    CYRUS2
    Help: 1241
    Rate: 3530
    I do not know.
    Kolobos wrote:
    I wrote that you uninstalled the updates, you did not write anything about it.
    I do not know what Mikrooft changed
    Faulty jet file Kernel32.
    If this file is installed before XP, I can copy it from the XP disc.
    If Kernel32 is modified by office 2010 then I have to install office 2010 twice.
    Do you have knowledge about this?
  • #8 17560188
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    So find out! Enter the update history and see what has been installed recently. In add-remove programs, select showing updates.
    Watpie to let Kernel32 be flawed as you said, you installed some libraries for a newer system, and I doubt that it would have to do with Windows Update.
    But it will be hard for you if you do not know anything.
    Office can be reinstalled and checked if it will work.
  • #9 17563092
    Luc0as
    Hello to my company in the company more and more computers from xp having office 2010 has this problem probably got some patch for the office that is scattering it but I still can not figure out which one.
    Added after 5 [minutes]:
    KB2863821 and KB4461522. From what I read, these patches should be uninstalled and everything goes back to normal.
    Added after 13 [minutes]:
    However, from my observations it appears that KB4461522 is the culprit.
  • #10 17563147
    CYRUS2
    Help: 1241
    Rate: 3530
    Kolobos wrote:
    Watpie, that Kernel32 was defective as you wrote, You have installed some libraries for the newer system .
    Why do you handle how you have no idea about IT.
    You will not add anything to or remove from catalogs.
    Lack of access.
    They installed it the day before yesterday.
    There is no update date.
    I can not even delete office 2010.
    There is information that office 2003 (which I never had) is damaged.
  • #11 17563276
    jarrod
    Help: 59
    Rate: 131
    I have already had 20 computers in my company. You need to uninstall KB4461522, and after the trouble.
  • #12 17579628
    CYRUS2
    Help: 1241
    Rate: 3530
    The reason is the 2010 office update.
    Microsoft's error or deliberate action.
After a recent automatic update of Windows XP, users are experiencing issues with Microsoft Word and Excel, specifically encountering a "no GetDataFormatEx procedure in the Kernel32.dll library" error. While Corel and Firefox function normally, the problem seems linked to updates affecting Office 2010. Suggestions include uninstalling recent updates, particularly KB4461522, which is suspected to be the culprit. Users are advised to check update history and consider reinstalling Office if necessary. Some users report difficulties in accessing update settings and managing installations.
TL;DR: On Windows XP with Office 2010, 20 PCs saw Word/Excel fail; "You need to uninstall KB4461522, and after the trouble." Remove that Office update to clear the KERNEL32.dll GetDataFormatEx error. [Elektroda, jarrod, post #17563276]
Why it matters: For XP + Office 2010 users asking how to fix Word/Excel startup crashes, this avoids risky system file changes.
What causes the “no GetDataFormatEx in KERNEL32.dll” error on Windows XP with Office 2010?
An Office 2010 update triggers this on XP. Users traced the crash to KB4461522, which prevents Word and Excel from starting. As one admin put it, “KB4461522 is the culprit.” Removing that update restores normal app launch. [Elektroda, Luc0as, post #17563092]
How do I remove a recent Office update on Windows XP?
Use Add/Remove Programs with updates visible. 1. Open Add/Remove Programs and tick “Show updates.” 2. Locate the latest Microsoft Office 2010 update entry. 3. Click Remove and restart Windows. Relaunch Word/Excel to confirm the fix. [Elektroda, Kolobos, post #17560188]
Which update should I uninstall to fix Word/Excel crashes?
Uninstall KB4461522. One admin resolved the issue on 20 company PCs by removing this update. “You need to uninstall KB4461522, and after the trouble.” Reboot after removal and test Office apps. [Elektroda, jarrod, post #17563276]
Do I need to reinstall Windows XP to fix this?
No. This is not a corrupted KERNEL32.DLL or XP problem. The malfunction comes from an Office 2010 update. Remove the Office update and test Word/Excel again. [Elektroda, CYRUS2, post #17579628]
Should I reinstall Office 2010 after uninstalling the update?
Usually you do not need to. If Word/Excel still fail after removing the update, reinstall Office 2010 to verify. “Office can be reinstalled and checked if it will work.” [Elektroda, Kolobos, post #17560188]
Do I also need to remove KB2863821?
Some systems showed both KB2863821 and KB4461522. Start by uninstalling KB4461522. If issues persist, remove KB2863821 as well. As one user concluded, “KB4461522 is the culprit.” [Elektroda, Luc0as, post #17563092]
I can’t uninstall Office 2010 and it says Office 2003 is damaged—what should I do?
Open Add/Remove Programs, enable “Show updates,” and remove the Office update entries. If the uninstaller is broken, reinstall Office 2010, then remove the updates again. This approach verifies and resets the installer state. [Elektroda, Kolobos, post #17560188]
Why am I seeing updates on XP if Microsoft ended support?
Because the problematic package is an Office 2010 update, not a Windows XP OS update. Removing that Office update resolves the launch failures. [Elektroda, CYRUS2, post #17579628]
Which applications are affected or unaffected by this issue?
Microsoft Word and Excel fail with the KERNEL32.DLL GetDataFormatEx error. Corel, Firefox, and internet access continue working normally on the same system. [Elektroda, CYRUS2, post #17559765]
Should I replace KERNEL32.DLL from the XP CD or edit the registry?
Do not replace system DLLs or edit the registry. The error stems from an Office update, not a damaged KERNEL32.DLL. Uninstall the Office update instead. [Elektroda, CYRUS2, post #17579628]
How widespread is this Office 2010 update issue on XP?
One administrator reported fixing the crash on 20 computers by removing KB4461522. That indicates a broad impact across similar XP + Office 2010 setups. [Elektroda, jarrod, post #17563276]
When did Windows XP last receive official OS updates?
A forum expert notes the last XP updates were around 2017. New OS patches are no longer provided for XP systems. [Elektroda, Kolobos, post #17559917]
How do I check what was installed recently on my XP machine?
Open Add/Remove Programs and enable “Show updates.” Review the latest entries to see recent Windows and Office changes. Remove suspect Office updates and reboot. [Elektroda, Kolobos, post #17560188]
Does this affect Office versions other than 2010?
This thread documents failures with Office 2010 on XP. No other Office versions were confirmed here. If similar errors appear, audit and remove recent updates first. [Elektroda, Luc0as, post #17563092]
