Laguna II Steering Lockout Error: Radio Lights Up, No Start After Inserting Card (2002 Model)
tomasz0703 15919 16
How do I fix a 2002 Laguna II that lights the radio but won’t start after inserting the card, shows a steering-lock error, and only clicks when the card is removed, and do I need to adapt the steering lock?
Yes — the Laguna II steering lock is adapted to the car, and a used lock from another vehicle is generally not reusable because the code is permanently learned; if you replace it, it should be matched/adapted to the vehicle [#8732218] [#8732254] One reply says the practical cure is to replace it as a set with the engine controller, cards and cabin unit, not just swap in a random used lock [#8732254] If the lock only ticks/clicks and sometimes does not engage, also check the mechanical side: the cross/tongue on the steering column may be too high/low, or the blocker may have burrs or be jammed [#8736606] [#8737770] The reported solved case ended up being a blocked bolt tongue [#9318246]
  • #1 8732035
    tomasz0703
    Help: 69
    Rate: 489
    Hello laguna II does not start after inserting the card (only the radio lights up) - in the electronic team there is a steering lockout error. After removing the card, the lock does not lock but you hear something ticking how it would lock. Is it necessary to adopt it? Auto 2002
  • #2 8732064
    Przemo9826
    Help: 374
    Rate: 2502
    In Laguna 2, the lock is not coded.
  • #3 8732218
    AREK_GDYNIA
    Help: 29
    Rate: 89
    quoted:
    CODING OF ELECTRICAL LOCK
    STEERING COLUMNS
    The electrical interlock is supplied as
    un-encrypted. When assembling in a vehicle it will be
    therefore, the necessary adaptation of its system code
    the start-up block to enable the ignition.
    Just enter the RENAULT card of the vehicle into
    reader for a few seconds. Take out the RENAULT card,
    the start-up function will be provided after a few
    seconds. The electrical interlock is coded, and
    the steering column is blocked.
    ATTENTION:
    In the described starting block system,
    the vehicle retains its start-up code on
    always.
    In addition, there is no code in this system
    Emergency.
    Therefore, it is forbidden to carry out
    trials with a loan lock
    warehouse, which should then be
    returned.
    The adapted code can not be deleted.
  • #4 8732225
    Przemo9826
    Help: 374
    Rate: 2502
    And this is not the case for Megane II Scenic II?
  • #5 8732249
    tomasz0703
    Help: 69
    Rate: 489
    So when I buy a used blockade, my ears will not accept this block because I see different opinions about it?
  • #6 8732254
    AREK_GDYNIA
    Help: 29
    Rate: 89
    No, this is copied from the Laguna II service book. Applies to the new steering lock. Unfortunately, it is not suitable for anything because it is permanently code-learned. You need to replace it in a package with the engine controller, cards and a combined unit in the cabin, but this can not come from the version with lower equipment.
  • #7 8732257
    KAROL1138
    Help: 9
    Rate: 103
    Oh Przemo, will you be sure?
  • #8 8732274
    Przemo9826
    Help: 374
    Rate: 2502
    I think I made a mistake, I'm sorry, I've already made a post to get it removed, so I will not make a mess.
  • #9 8732321
    tomasz0703
    Help: 69
    Rate: 489
    What is in this bolt there is some eprom. So how do I fly the eprom from my lock to the bought one?
  • #10 8736588
    maddob
    Rate: 11
    I join the topic. Is it possible to convert the memory chip from my old lock to some used one? I have a LII PHI from 2004. The problem with my car is that every now and then the car can not be ignited (the immo indicator is on), it helps the driver to rapidly move the steering wheel alternately to the right and left. The problem occurred after the mangement regeneration. The lock bolt locks the steering wheel once and not once. Fault so insolent that I do not know when I can leave :)
  • #11 8736606
    Przemo9826
    Help: 374
    Rate: 2502
    Because the "cross" on the transmission is wrong, too low or too high, so it does not catch the blockade.
  • #12 8736640
    maddob
    Rate: 11
    and this is the reason for problems with starting the car and lighting the immo control? The blockade sometimes catches, sometimes not. Can this be somehow improved or already damaged on amen?
  • #13 8736647
    Przemo9826
    Help: 374
    Rate: 2502
    And exactly what does it mean sometimes it does not catch sometimes? Do you pull out the card and you can turn the wheel?
  • #14 8736790
    maddob
    Rate: 11
    Sometimes when I pull out the card the lock surprises and locks the steering wheel. I am more worried that from time to time I can not start the car, help me to turn the steering wheel right and left, sometimes even for 10 - 15 minutes :( without a lock, you can ride ... and the possibility of firing is rather necessary
  • #15 8736886
    ozi-77
    Help: 8
    Rate: 106
    I would advise you to drive somewhere on the clip, you will save your time and money best for Renault service, because so far you have not been anywhere, and this is the basis in today's cars, then you can think something, just go to the site and not somewhere Garages, because you can not do anything
  • #16 8737770
    jurekk55
    Level 36  
    Help: 182
    Rate: 1580
    maddob wrote:
    Sometimes when I pull out the card the lock surprises and locks the steering wheel. I am more worried that every now and then I can not start a car, it helps to turn the steering wheel sharply to the right and left, sometimes even for 10 - 15 minutes :( without a lock can be driven ... and the possibility of firing is rather necessary
    Disassemble the blocking module check the functioning in the "air", after pulling out the deadbolt, gently remove the metal burrs (if any), dismantling only if you have worked on the scrap metal before!
    The rest prohibits the rules of :D
  • #17 9318246
    tomasz0703
    Help: 69
    Rate: 489
    The problem solved was blocked by the bolt tongue.
The discussion revolves around a steering lockout error in a 2002 Renault Laguna II, where the vehicle fails to start after inserting the key card, with only the radio lighting up. Users note that the steering lock is not coded and requires adaptation for the ignition system to function properly. It is emphasized that the electrical interlock is permanently coded and cannot be reused from another vehicle without replacing it alongside the engine controller and key cards. Some users report intermittent starting issues related to the steering lock mechanism, suggesting that the lock may be malfunctioning or blocked. Recommendations include consulting a Renault service for proper diagnostics and repairs, as DIY fixes may not resolve the underlying issues.
