Toshiba 1TB External Drive Not Detected: USB 3.0 to SATA II+IDE, Visible in Disk Management
batonik78 6723 7
  • #1 16491942
    batonik78
    Good day.
    I have a problem with a toshiba 1TB external drive. The disk is connected via (probably an external controller) USB 3.0 to SATA II + IDE. The computer cannot see the disk in "devices and disks" but is visible in computer management / disk management. On the factory controller it is not even visible in disk management. In disk management, the disk has no drive letter assigned and after pressing PPM, only the "delete volume" and help are available in the menu. There is a lot of data on the disk that I would like to recover. Is there any possibility and if so, what program. Please help
    PS My friend's work disc, so I don't really know what was done with him.
    Sebastian
  • #2 16491949
    kindlar
    Help: 919
    Rate: 1622
    Start DMDE and check.
  • #3 16491955
    kaes2000
    Rate: 47
    Try on a better cable. I have an old toshiba 320 usb and the computer sees it as it pleases. Sometimes after the third call.
  • #4 16491979
    batonik78
    I don't know this program. What would I check and how?
    As for the cable, it was checked on two different cables on 4 computers. Each time the same effect
  • #5 16491995
    Łukasz_W
    HDD and data recovery specialist
    Help: 633
    Rate: 658
    Provide SMART disk.
    In DMDE you have to show if it detects any content.
    HEX SERWIS
    Smołdzinska 2B/16, Kobysewo, 83-304 | Tel.: 530XXXXXX (Show) | Company Website: https://hex-serwis.pl
  • #6 16492114
    kaes2000
    Rate: 47
    Maybe it needs extra power? You write USB 3.0 to SATA II + IDE.
    That would mean that this is not an external drive, just a normal one connected with an adapter and then you need a power supply.
  • #7 16502753
    laptokowiec
    Help: 112
    Rate: 120
    Use DMDE - there are a lot of posts on the Forum discussing what and how.
  • #8 16502768
    RADU23
    Help: 2428
    Rate: 1732
    First, include a DMDE screen with a partition layout.
    Łukasz_W wrote:
    Provide SMART disk.
    Use =>
    http://crystalmark.info/software/CrystalDiskInfo/index-e.html
    Look =>
    https://www.youtube.com/watch?v=g6O9uHNuORE
A user is experiencing issues with a Toshiba 1TB external drive connected via a USB 3.0 to SATA II + IDE adapter. The drive is not recognized in "devices and disks" but appears in Disk Management without a drive letter, limiting options to delete the volume. Suggestions include using the DMDE software to check for content and SMART status, ensuring the drive has adequate power, and trying different cables. Users recommend providing a screenshot of the partition layout and utilizing CrystalDiskInfo for further diagnostics.
