Windows 7 64-bit Purchase: Affordable, Original Version - Price Range & Trusted Sources
GRdeR20002 3072 5
  • #1 16493686
    GRdeR20002
    Hello, I am going to buy Windows 7 64bit version, after a short search I came across a complete price range from 30 to 500 PLN. My question is where to buy in order not to overpay and be sure that the system is original. Best regards!
  • #2 16493716
  • #3 16494004
    revolt
    Help: 159
    Rate: 186
    You can reject all wonderful auctions from the Allegro, such as a machine that sends the code right after the payment. By buying at these auctions, you can only cause yourself problems (ironically, it's better not to buy at all). Search in some electronics stores or chains or on the MS website. From what I can see, about PLN 460 in "normal" stores for the Home version is a standard.
  • #4 16495150
    atomic99
    Help: 171
    Rate: 338
    @ cristal2242 I wonder where you will find for PLN 300, throw the line with 100% legal OEM.
  • #6 16559458
    Mac!
    Help: 19
    Rate: 27
    From the normal Polish distribution of win7, you probably won't get 10 items in stores. On the Allegro these keys / licenses are questionable. I guess no one here will tell you if the license is legal, it's best to buy and call the microsoft then you will find out. On the other hand, if someone invoices you for the software, you are not a holy spirit to know if it is legal.
