Seat Leon II 2007: Left Reversing Light Not Working, Bulb & Fuses Checked, Seeking Advice
laurajulia 12906 9
Why does the reversing light on a 2007 Seat Leon II not work even after checking the bulb and fuses?
On the Seat Leon II there is only one reversing light, and it is on the right side in the tailgate; the left lamp is the fog light [#16495804] If the real problem is the third brake lamp/LED strip, it is probably damaged, and you should check that power reaches the connector/cube before replacing or repairing it [#16502113][#16496910] That lamp can probably be repaired, while a new original unit costs about 350 [#16496910] A fault may also be stored in BCM module 09, and it should clear after the fault is fixed [#16496910][#16498651]
  • #1 16495611
    laurajulia
    Rate: 47
    I have a problem with the reversing light in Seat Leon II, year 2007. The information is on that the burnt-out light bulb, like nothing shines in the left reversing lamp (right light), the bulb OK, has been replaced, all fuses OK.
    What could it be?
    Greetings, Marek.
  • #3 16495664
    laurajulia
    Rate: 47
    OK, I'll check tomorrow and let you know.
    jacek074
    Level 30  
    Help: 190
    Rate: 727
    But in this model there is one reversing light, on the right in the tailgate, on the left is fog. All lights checked front and rear?
  • #5 16496727
    laurajulia
    Rate: 47
    Thanks for the interest and thanks to jack 074, actually this fog lamp is working.
    It turned out that the STOP flap does not light, this led strip. Hence my new question - can only the LED strip be replaced? Why did it burn, car mileage 140,000, maybe it didn't burn, but something else?
  • #6 16496910
    jacek074
    Level 30  
    Help: 190
    Rate: 727
    It can probably be repaired, new original about 350. According to me the third stop lamp alone should not light the lamp indicator. Positions in the back are double? There should be an error in the bcm (09) driver's memory that lights up the indicator.
  • #8 16498651
    jacek074
    Level 30  
    Help: 190
    Rate: 727
    I will not recommend the cable, certainly with can. He can go somewhere just to check the faults. If you remove the fault, the indicator will turn off by itself.
  • #9 16501867
    laurajulia
    Rate: 47
    Well, but what about this stop, it doesn't shine, why? is this also the result of an error? Best regards and thank you jacek074 for valuable advice
  • #10 16502113
    jacek074
    Level 30  
    Help: 190
    Rate: 727
    It is not lit because it is probably damaged, before replacing (repairing) you need to check the power supply in the cube.
The discussion revolves around a malfunctioning left reversing light in a 2007 Seat Leon II. The user confirmed that the bulb and fuses are functional, prompting suggestions to check the voltage at the rear lamp. It was clarified that the left side is a fog lamp, while the right side is the reversing light. The user later discovered that the STOP lamp does not illuminate, leading to inquiries about the possibility of replacing the LED strip and the cause of its failure. Responses indicated that the LED strip might be repairable, and issues could stem from an error in the body control module (BCM). Further advice included checking the power supply before any replacements.
