BMW E39 1998 with 2.8L LPG Engine - Excessive Cooling System Pressure Causing Component Damage
maylo 13113 7
  • #1 16496688
    maylo
    Help: 96
    Rate: 94
    Hello everyone, I have a problem with a good E39 from 1998. The engine is "reliable" 2.8 L assisted by LPG :) . Well, there is too much pressure in the cooling system - damaging every now and then new elements of the system. Driving like nothing is happening - the temperature tip "stands" in the middle. After a few hours (4-6h), unscrew the cork - the geyser from the fluid up. Currently, after replacing the radiator (in the previous one it burst the tank), water pumps, several hoses, and I replaced the cork with the original one. Currently there is a bulge on the reservoir of fluid next to the radiator and so you should expect another replacement ... I will add that the car was properly vented and the mechanic did not find any signs of exhaust fumes. Sometimes I can skip 800km to cool the car and after 4 hours, unscrew the stopper and it is light "psst" and no "geyser" then the next day passing the distance, eg. 10 km, unscrew after the same time and crashes the liquid. There were 3 mechanics in the car - none of them can determine exactly what is wrong. Do you have any idea?
  • #2 16496712
    robokop
    Help: 1763
    Rate: 6372
    You have. They burn the exhaust to the fluid, even though the mechanic did not find it, or the engine, however, works at a much higher temperature than the indicator shows. Did you create a new or used cooler?
  • #3 16496732
    maylo
    Help: 96
    Rate: 94
    I exchanged for the used - original - 100% ok - the cooler came with a car on wheels which went into demolition for parts. Well, but with exhaust gases in the system there is probably no chance to make such long distances? and how do you explain the inability to detect them in the system when testing CO2?
  • #4 16496778
    robokop
    Help: 1763
    Rate: 6372
    For me the indicator is yellow, and yet I normally ride. And how do you explain it? Please check the actual engine temperature with an independent thermometer, we will know what we are talking about.
  • #5 16496830
    sigwa18
    Help: 1194
    Rate: 3359
    Most 1.9 TDI pd series A that the VAG stable has this problem. I would put a pressure gauge and check what is actually the pressure in the system, especially after driving with the gas pedal in the floor. Puki releases a little cork, it manages to drop the excess. Then he spits liquid and the liquid slowly disappears. In the last phase of the exhaust there are so many that the cork can not keep up and the weakest part in the system, eg hoses, heater, radiator, falls. Some add liquid and continue after tens of thousands of miles while driving peacefully and looking for a hole in the cooling system. So that the 99 percent cap up and a new gasket.
  • #6 16496856
    kortyleski
    Help: 957
    Rate: 3860
    In the case of this motor and these symptoms it is rather a cap up and no cracked used in its place.
  • #7 16498995
    maylo
    Help: 96
    Rate: 94
    The diagnosis is always the same - the head for removing and replacing the gasket or head ... what if the problem remains after replacing these elements?
    Initially, devoting a few hours and a few liters of mountains managed to find a problem - at the moment in the testing phase.
    Well, the problem probably turned out to be ... leaky evaporator, pumping gas into the cooling system .. because after unscrewing the radiator cap and raising the revs to about 3000 you could feel a distinct smell of gas from the equalizing reservoir.
    Currently, I burned the gas that was in the system and drive with a twisted valve on the cylinder and in the mode "PB MODE" after the whirl in the wallet no leaks, squeeze snakes (previously swollen to the limit) in the morning lack of geyser after cooling down. If nothing happens - the evaporator to be replaced.
    I'll let you know about the results
  • #8 16499034
    sebap
    Help: 538
    Rate: 1082
    So the Magic reducer is there?
The discussion revolves around a 1998 BMW E39 with a 2.8L LPG engine experiencing excessive pressure in the cooling system, leading to component damage. The owner has replaced several parts, including the radiator and water pump, but the issue persists. Responses suggest potential causes such as exhaust gases entering the cooling system, a faulty radiator cap, or a leaky evaporator. The owner suspects the evaporator may be the source of the problem after detecting a gas smell in the reservoir. Current testing involves running the vehicle in "PB MODE" to monitor for leaks and pressure issues.
