BMW E46 320i M54B22 - High Cooling System Pressure, Radiator Replacement & CO2 Test Results
Smule 11760 4
  • #1 16412862
    Smule
    Rate: 13
    I warmly welcome,
    I took the car from Germany, returning to Poland with zero problems, when I returned it blew up the radiator and there was a puddle under the car. The mechanic installed a new radiator and decided (because these internal hoses were swollen) that pressure was coming from the head. They did the Co2 test and the color changed fluid.
    I will add that there are no other symptoms of a damaged gasket under the head, it does not kick, it fires without problems, there is no oil in the coolant or water under the oil filler cap / bayonet.
    Before I decide to spend money on renovation, I would like to make sure that it is 100%. Is there any other symptom that could cause excessive pressure in the cooling system and the above-mentioned effects? I don't have LPG.
    E46 320i
    M54B22
    Greetings.
  • #2 16413017
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    It can be a head, but if you have doubts about the mechanic, buy a tester, for example ... or drive to another specialist. It happens that these German cars bought straight from the Turk or Lithuanian have such bonuses and sellers blow the thermostat away so that the customer goes away.
  • #3 16413034
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    And what to add here, the color detected CO2 you have pressure, what else do you need?
  • Questioning radiator failure despite no overheating or coolant loss while drivin
    #4 16413199
    Smule
    Rate: 13
    Ok thank you for the answers.
    I have little doubt about this diagnosis, I have not seen this test for living eyes.
    The car drove 1000km and everything was fine.
    A few days later another 100km, no loss of coolant.
    Then the car stood and during the parking under the house the water light came on ...
    I look and there is nothing but nothing, I added, the next day I look and again little, the water ran away very quickly at a standstill. And the diagnosis in the service - a blown radiator.
    I did not heat the engine even once.
    Is it even possible for the radiator to go like this?
  • #5 16413261
    web69
    Help: 188
    Rate: 629
    No, just like that ... you have a blow to the cooling system, a few more days of such experiments and you will be looking for an engine.
