PENTAGRAM P6360 Router: Wifi Amplifier Recommendations for Stronger Range on Upper Floor
ppp47676 7848 12
Can I improve Wi‑Fi coverage on the upper floor with a wireless repeater, and does it need an RJ‑45 cable?
A Wi‑Fi repeater connects wirelessly, so it does not need an RJ‑45 cable, but the most stable and best-quality solution is to run a LAN cable upstairs and install an additional access point there [#16497964][#16498607][#16499783] If you use a repeater, place it in a good spot between the router and the weak-signal area, but expect lower performance because it can cut speed roughly in half and may cause packet loss or high ping [#16500311][#16500441] For a 6 Mb/s connection, a cheap repeater or PLC/powerline adapters should be enough [#16499469][#16499587][#16499783] If your router’s LAN ports are already occupied, add a cheap switch to free one port for the upstairs access point [#16500441]
  • #1 16497954
    ppp47676
    Rate: 22
    Hello, I have a PENTAGRAM P6360 router and the question is whether the wifi amplifier alone is enough to have a stronger range on the floor? I have a router on the ground floor. And to such an amplifier you need to connect an rj-45 cable or just connect wirelessly?
    Regards
  • #2 16497964
    Barton-wlkp
    Help: 26
    Rate: 90
    As far as you talk about a repeater it connects wirelessly.
  • #3 16498397
    Vieslav889
    Help: 23
    Rate: 28
    That's how quickly I can offer TP-Link TL-WA850RE.
    Write also how much space you want to cover, where there are currently no coverage, and what internet you have.
  • #4 16498607
    hermes-80
    Help: 1177
    Rate: 743
    You will achieve the best quality by connecting another AP (upstairs) with a LAN cable and pentagram.
    I do not recommend amplifiers.
  • #5 16498653
    jprzedworski
    Help: 758
    Rate: 828
    Such an "amplifier" should be somewhere halfway. If you have a router downstairs and a computer one floor above, where do you place it? In the ceiling? ;-)
  • #6 16498739
    ppp47676
    Rate: 22
    Only this router has only 2 LAN outputs and both are occupied: /
    And buying a better one will cover the entire ground floor and floor?
    How so, what?
  • #7 16498827
    Vieslav889
    Help: 23
    Rate: 28
    Write what your internet speed is and whether there is something transmitted through your home network locally, otherwise you can't determine what will be best.
  • #8 16498985
    Barton-wlkp
    Help: 26
    Rate: 90
    There is only one AND internet and everyone has the same.
  • #9 16499469
    ppp47676
    Rate: 22
    Internet 6 Mb / s
  • #10 16499587
    sebap
    Help: 538
    Rate: 1083
    Twisted pair or PLC adapters, and at this speed the cheapest adapters will do their job perfectly.
  • #11 16499783
    Vieslav889
    Help: 23
    Rate: 28
    ppp47676 wrote:
    Internet 6 Mb / s
    In that case, this repeater proposed by me should give advice. However, the most stable solution will be pulling the twisted pair to the first floor and placing the AP there.
  • #12 16500311
    sebap
    Help: 538
    Rate: 1083
    Repeater put at a good point at any speed will manage but cut this speed by half.
  • #13 16500441
    Sztandar18
    Help: 75
    Rate: 104
    The internet will work with the repeater, but if you like to play some online games, packet loss / ping pings will bother you a lot. I know this from my own experience, I have this configuration:
    Router (TP-LINK TD-W8960N) + Repeater (TP-LINK TL-WA750RE)
    The repeater is set to 70% of the router's range. Unfortunately, it works so that when pinging the router through cmd, the packet is lost from time to time, the ping jump up to 200 ms in a moment, the accumulation of 10-20 pings with a value of 100-400 ms after a while and this situation repeats endlessly. If you have the option, lay the twisted pair cable and place an additional Access Point. Repeater from an autopsy I DO NOT RECOMMEND.
    From what I see, you write that you have two of the two available LAN ports occupied in the router, the solution - unplug one device from the LAN port, plug the cheapest Switch there and plug these two devices into this Switch.
    In summary, it should look like this:
    Switch plugged into the router's LAN1 port
    Access Point plugged into the router's LAN2 port
    Two devices plugged into the switch port, e.g. LAN2, LAN3.
    Problem solved.
The discussion revolves around enhancing the Wi-Fi range of a PENTAGRAM P6360 router, particularly for coverage on an upper floor. Users suggest that while a Wi-Fi amplifier (repeater) can connect wirelessly, the best performance is achieved by using a wired connection to an additional Access Point (AP) on the upper floor. Recommendations include the TP-Link TL-WA850RE repeater, but concerns are raised about potential speed reduction and packet loss when using repeaters, especially for online gaming. Users also discuss the possibility of using a switch to expand LAN ports if all are occupied.
