TP-Link TL-WA850RE with Huawei B535-232 - no improvement in coverage on _EXT network, why?
MihalskiP 675 1
  • Weak router signal and foil-insulated walls limit repeater gain
    #1 21583645
    MihalskiP
    The TP-Link TL-WA850RE repeater connected to the Huawei B535-232 router does not amplify the signal.
    The devices work correctly, on the extended network _EXT there is no signal amplification at all. What could be the cause? Can generally weak internet from outside cause this? Even if it is weak, it should be amplified?
    AI: At what distance from the router does the repeater stand and are there any walls or obstacles in the way? .
    8 m, cardboard-gypsum walls with alu foil and 5-10 cm of wool
    AI: Where the repeater stands, is the Wi-Fi signal from the router already weak or rather strong? Have you checked this with your phone, for example? .
    Repeater in another room on the ground floor, the signal from the router is rather weak 7-10 Mbps at peak, sometimes 20-40 Mbps off peak users
  • #2 21583696
    KOCUREK1970
    Help: 3862
    Rate: 5490
    @MihalskiP
    If Wi-Fi coverage is lacking somewhere, we lay a twisted pair cable and install a local AP.
    We then connect this AP with this network cable to the main router.
    All other ideas like amplifier, repeater - can be put into the fairy tales.
