Citroen C5 III: Rear Parking Sensors Not Working After Clutch Replacement
krzysztof0 9924 8
  • #1 16498360
    krzysztof0
    Rate: 13
    Hello, I recently have a C5 III, recently replaced the clutch mechanic because I was a little buzzing as I pressed the clutch. And what turns out that recently I back up the car and here after turning on the reverse there is no parking assistant signal, the sensors on the back also do not work, the computer does not report any errors, so I purchased lexia on a well-known auction portal, I start the diagbox (of course zero errors) I enter the coding manual and there is only the option of "front parking assist" from the sensors and where my rear sensors could suddenly disappear? is it possible that something "broken" by the mechanic as he replaced the clutch?
    I will be grateful for the hints, because if I come up with nothing, an ASO awaits me :-( ,massacre.
    • Citroen C5 III: Rear Parking Sensors Not Working After Clutch Replacement lexia.jpg (50.38 KB) You must be logged in to download this attachment.
  • #2 16498363
    szymitsu21
    Help: 343
    Rate: 1300
    reverse lights work?
  • #3 16498529
    krzysztof0
    Rate: 13
    reverse lights don't work either :-(
  • #4 16498620
    andrzej20001
    Help: 1578
    Rate: 6669
    Then plug the sensor plug
  • #5 16498694
    krzysztof0
    Rate: 13
    Do you know where it is? :-)
    PS. the mechanic was changing the clutch for me, maybe it broke off or didn't connect
  • #6 16498704
    andrzej20001
    Help: 1578
    Rate: 6669
    Think what implements backlink. And what should turn on the reversing light. Dzizus why lexia ??? Use the brain
  • #7 16498734
    krzysztof0
    Rate: 13
    No, Andrzej! , thanks for the great tips and advice !!. Yes, I have to use my brain.
    It will be shot in 10.
  • #8 16498761
  • #9 16498836
    krzysztof0
    Rate: 13
    wacmean wrote:
    Come to this mechanic and let him correct what he did not ... he took out your ankle that activated the reversing light in reverse and did not put it in again
    and I can't? where is the cube?
The discussion revolves around a Citroen C5 III experiencing non-functional rear parking sensors and reverse lights following a clutch replacement. The user suspects that the mechanic may have inadvertently disconnected or damaged a component during the clutch work. Responses suggest checking the sensor plug and the reversing light activation mechanism, with advice to consult the mechanic for corrections. The user expresses frustration over the situation and the potential need for professional assistance.
