[Solved] Seat Leon 3 FR: Parking Sensors Not Working, No Error Shown – Possible Causes & Solutions
misieq1993 19596 6
  • #1 17144384
    misieq1993
    When I start the car, it throws me the information "signaling when parking. the function is currently unavailable.
    After pressing the parking assist a continuous signal and after a while nothing happens.
    Someone had a similar problem? Original sensors - it is possible that one of the sensors does this if one piece is damaged? The error does not show, and does not work front and back ..
    kowal5
    Help: 25
    Rate: 69
    Yes. If one of the sensors fails, the entire system will stop working. Connect the packaging support system to the appropriate diagnostic equipment to determine the cause of the failure.
  • #3 17144669
    misieq1993
    I have no other diagnostic device. But I have sensors from the second bumper, because it was replaced - I will try to replace it, maybe it will work.
    I understand that if one of the front is damaged, the back is also inactive in the entire system?
  • #4 17144771
    yanes
    Help: 211
    Rate: 610
    This "diagnostic device" is probably a VCDS cable, maybe one of your colleagues will have it connected to you. You can check by hearing, a good sensor ticks every half second, or put your finger on it, you should feel a tingling sensation.
  • #5 17144982
    misieq1993
    It's interesting - tomorrow I will check according to what you write, i.e. by hearing and touching :) Will they tick even inactive if I get close to them to check? Because the system cannot be turned on since the message says that it is unavailable.
    yanes
    Help: 211
    Rate: 610
    I have never checked it myself, but it seems to me that the reverse should be on or press the button in the cabin.
  • #7 17149934
    misieq1993
    It worked - they all tick after turning on the parking mode as you wrote :)
    It's good that I did not start to unscrew the bumper. I went to the guy under the vaga and it turned out that there was a mistake. Once removed, everything works normally
The discussion revolves around a malfunctioning parking sensor system in a Seat Leon 3 FR, where the user experiences a message indicating that the parking function is unavailable. It is noted that if one sensor fails, the entire system may stop working. Users suggest using diagnostic equipment, such as a VCDS cable, to identify the issue. The author later discovers that all sensors function correctly after checking their operation and consulting a technician, who confirmed a previous error that was resolved.
