Citroen C5 2010: Parking Brake Blocked - Emergency Release Methods & Information
jarko2f 9966 5
  • #1 16514411
    jarko2f
    Rate: 50
    Hello, I have a problem with C5. Parking brake blocked, is there an emergency way to release this brake in these cars ??
    thanks in advance for info
  • #2 16514577
    rosak
    Car dashboards specialist
    Help: 142
    Rate: 559
    Maybe if you write what you mean, someone will help. What is the handbrake as in the title or automatic parking. What does it mean that it is stuck?
  • #3 16514618
    lukash3
    Help: 24
    Rate: 133
    Under the center console cover you have an element that needs to be pulled.
  • #4 16514663
    jarko2f
    Rate: 50
    ok. I'll write again though, it seemed to me quite clearly described the problem, just the automatic parking brake has locked and you can't release it, the rear wheels are locked. I have a question, therefore, whether it is possible to manually release this brake manually.
  • #5 16514677
    ociz
    Help: 1379
    Rate: 3486
    And you know that this information is in the user manual?
    Yes, there is a possibility. The cable goes from the mechanism and its end is in the armrest, under the rubber.
  • #6 16536707
    jarko2f
    Rate: 50
    Thanks for the hints. I'm closing the topic
