Best Car Battery Rectifier for Long Stops: Recommendations & CTEK MULTI XS 3600 Review
Davidzior 6513 5
  • #1 16499523
    Davidzior
    Rate: 18
    Could you recommend me a rectifier that I could connect to the car (passenger car) for a long stop. I am traveling abroad and I would not like the battery to die (the car will rarely start). I would like to buy something better and relatively trouble-free (proven). I read about CTEK MULTI XS 3600. Do you know this model?
    rafbid
    Help: 153
    Rate: 418
    Virtually every charger / charger will be good that resumes charging itself after a power outage. Personally, for several years I have been using the SENA charger with a ladybug for PLN 49, supports 3 cars, 2 tractors and a combine harvester and two additional batteries. The CTEK MSX 5.0 charger has good reviews, it has more programs, 5 A charging current, and 5 years warranty.
  • #3 16499589
    enhanced
    Help: 963
    Rate: 883
    Will this be used for one car? Maybe it's better to buy a battery? Well, unless it eats so hard and stops once a month.
  • #4 16499602
    Davidzior
    Rate: 18
    Well, it will be launched rarely. In addition, it will be useful during winter, because it is a "rally" car, not for everyday driving :)
    The charger will be used mainly for this car, but I will definitely use it for others sometimes.
  • #5 16499726
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    You can buy for 70, - in Leroy merlin, castorama, macro.
  • #6 16499786
    Davidzior
    Rate: 18
    I ordered CTEK MSX 5.0. You can close the topic. Thanks for the help.
