Choosing Replacement Speakers for Passat B5 FL: GMS-1865 vs BLAUPUNKT Pure 66.2
noidemm 16644 9
Which 16 cm replacement speakers should I choose for a Passat B5 FL with a stock Pioneer 4x50W radio and no amplifier?
For this setup, it is usually better to keep or replace the original VW/HAES speakers than to buy cheap branded aftermarket ones, because in this price range they may not sound better and you would just overpay [#16251859] [#16252227] One reply specifically says to buy original HAES speakers for the front, while using Blaupunkts only at the rear where there is no tweeter [#16272999] If you choose coaxial speakers like Blaupunkt Pure 66.2, the tweeter is built into the speaker, so you would not keep the separate mirror-mounted tweeter; the thread also suggests avoiding tweeters mounted low in the door if you care about sound staging [#16252756] [#16252771]
  • Choosing replacement speakers for unamplified Passat audio
    #1 16250675
    noidemm
    Rate: 254
    Hello. In my Passat my speakers ran out (one is broken - the diaphragm has broken). I would like to invest in some speakers, but there is a problem what ?? In the car a normal Pionieer radio (4x50W) without any amplifiers. The factory guys are 16 cm. Should you be guided by the company ?? Maybe you recommend something. The car is not tortured at full music ;-)
    Many people praise the GMS-1865 speakers. The price range even suits me. From what I remember, the subwoofers are still leaving the original speakers.
    Still caught my eye: BLAUPUNKT Pure 66.2
  • #3 16251822
    noidemm
    Rate: 254
    Comprehensive answer ;-) So I understand that for PLN 150 all loudspeakers from Pionieer, Blaupunkt etc. will be worse than the original ones ?? Do not look for branded ones, just put the original off the ground ??
  • #4 16251859
    powalla
    Moderator of CarAudio
    Help: 847
    Rate: 737
    noidemm wrote:
    will they be worse than the original ones?
    Maybe otherwise> they will not be better, so why overpay? ;)
  • #5 16251910
    noidemm
    Rate: 254
    I looked at alledrogo and serial speakers go from 30 to 50 PLN per item. For this price I think it would be better to buy some Lanzary or other Chinese Blaupunks :-D
    Now the question is when buying BLAUPUNKT Pure Coaxial 66.2 loudspeakers (in the description the tweeter) will you need to mount this original small tweeter which sits near the mirror ??
  • #6 16252227
    adam_1991r
    Help: 83
    Rate: 154
    I used to put on some blaupunkt speakers and the owner returned to the original after a week :) I think golf what I remember. Cars of the VW group even have good originals.
  • #7 16252756
    powalla
    Help: 847
    Rate: 737
    Want tweeters at the height of your socks?
  • #8 16252771
    noidemm
    Rate: 254
    Want ;-) And seriously, it's probably better if they are at chest height ;-) So look without tweeters.
  • #9 16272999
    noidemm
    Rate: 254
    I bought the rear blaupunks because it was not at the back. The problem will be if the wires are not left in the door. Now I will buy original HAES on the front. Does anyone have such for sale ??
  • #10 16275074
    noidemm
    Rate: 254
    I have a question. Looking through the auctions at alle ... ro.pl many original speakers with the VW badge are blaupunkt. There were HEAS. Will blaupunks play as nicely as these HEASs ??
The discussion revolves around selecting replacement speakers for a Passat B5 FL, specifically comparing GMS-1865 and BLAUPUNKT Pure 66.2 models. The user seeks advice on whether to opt for branded speakers or stick with original factory options, given the limitations of a standard Pioneer radio (4x50W) without amplifiers. Responses suggest that many aftermarket speakers may not outperform the original ones, and some users recommend considering original VW speakers, which are often Blaupunkt. There are concerns about the necessity of additional tweeters when installing the BLAUPUNKT Pure 66.2. The conversation also touches on the availability of original speakers and the potential quality comparison between Blaupunkt and HEAS models.
