[Solved] Translating Power Windows to Electric in Fiat Seicento 2000: Components Included?
kj01 11643 6
  • #1 16503078
    kj01
    Rate: 53
    Hello, did anyone translate the power windows to electric. What is included in the set because they are on sale - engine lifter + switches and that's all. I won't need a module or relays yet?
    Maybe someone has such a set I will buy back.
  • #2 16503228
    web69
    Help: 188
    Rate: 629
    There is no philosophy, buy a set with rubber door entries (if you don't have one). There is no module, you only connect the power supply after the ignition switch.
  • #3 16506720
    kj01
    Rate: 53
    Hello, maybe someone has scheme No. 10.22 - from the book about Seicento - scheme of connecting electric windows. In my version just this pattern is missing.
  • #4 16527031
    kj01
    Rate: 53
    Hello, I connected the whole set of electric windows and central locking. Central works as it should. Today, I got glass control switches and a relay. After connecting, everything works for a short time but even though I connected the relay to the right place on the F2 fuse, there is still no voltage. The current is only on the orange wire marked in the diagram. Maybe someone will tell you what is wrong. All fuses checked, relays too.
  • #5 16530525
    Hart3
    Help: 100
    Rate: 479
    Check if the relay on pin 85 has mass and maybe there is no power at terminal 30.
  • #6 16530638
    grala1
    VAG group specialist
    Help: 1496
    Rate: 5053
    I suggest you take a 21W light bulb and check if it lights up if you attach it between:
    - 86 a mass when the ignition is on
    - 85 a plus
    - 30 and mass
    - 87 a mass when the ignition is on
    Of course, the plus and mass to which you connect the bulb must be certain.
    Sometimes this check is better than the meter.
    After that you will see what the fault is.
  • #7 19797995
    kj01
    Rate: 53
    Cable mistake. Works to this day
The discussion revolves around converting manual windows to electric in a Fiat Seicento 2000. Users inquire about the necessary components for the conversion, confirming that a module is not required, and only a power supply connection after the ignition switch is needed. One user seeks a specific wiring diagram (No. 10.22) for electric windows. Another user shares their experience of connecting electric windows and central locking but encounters issues with voltage at the relay despite checking fuses. Suggestions include verifying relay connections and using a light bulb for troubleshooting electrical issues.
