[FIAT PANDA 2004] - Connecting Universal Central Lock: Wiring and Motor Instructions for DIY
kempes221 13356 13
How do I connect a universal remote central-locking module and a 2-wire actuator in a Fiat Panda so the driver's lock triggers the factory central locking?
Connect it as diagram D: the two actuator wires go only to the remote-control module, with no connection to the car’s electronics if the original central locking is otherwise intact [#16352917] Feed the module with constant power and ground: orange and orange/black to ground, yellow and yellow/black to +12 V [#16352885][#16352917] The upper relay handles lock/close and the lower relay handles unlock/open, so one actuator wire is switched to +12 V depending on the command while the other stays at ground [#16352917] Diagram A is only the internal relay wiring of the control unit, not the car connection; for the added actuator use the lower-left/D wiring [#16352964] If the system closes when you press open, simply reverse the two actuator wires [#16352894]
  • #1 16352756
    kempes221
    I warmly welcome,
    Well, I have a problem with connecting the universal central lock in the panda. I must have searched the entire internet and found no solution. The lock is such that they close and open all doors after turning the driver's key. I have equipped the driver lock cassette with the missing motor from which 2 cables come out. And all in all, it is enough for the central operation to connect the control unit to it from the remote control, because it will work as if I turned the key. The motor works in such a way that: Closing - (green cable + 12v and ground on blue) Opening - (green cable ground and blue cable + 12v). For China, I can't get to how to connect it to the switchboard. I will provide a diagram in the attachment.
    Best wishes :)
  • #3 16352847
    piotrek22101
    Help: 695
    Rate: 1421
    According to diagram A Bottom left.
  • #5 16352863
    kempes221
    I connect yes - white to blue and white with a black stripe to green (signals to open close) yellow and yellow and black should I connect + 12 and ground?
    piotrek22101
    Help: 695
    Rate: 1421
    Orange and orange black to the ground, yellow and yellow black to the plus. The other two for the actuator.
  • #7 16352891
    kempes221
    tomorrow morning I will let you know if it worked. Thank you very much
  • #8 16352894
    piotrek22101
    Help: 695
    Rate: 1421
    In case it closes after pressing open, then reverse the connection of the two to the actuator.
    tzok
    Help: 3176
    Rate: 6549
    If the entire installation is original, you only add an actuator with 2 wires and it will be controlled by a remote control unit, then you only need to connect this actuator to the control unit, without any connection to the car's electronics - diagram D is correct. You must enter 2 constant pluses and 2 constant masses for the control unit relays, i.e. orange and black orange to ground, yellow and yellow black to plus, the other two to the actuator. The upper relay responds to the closing signal, the lower relay responds to the opening signal. So you normally have 2 masses on the actuator, and depending on whether you close or open, one of them changes to 12V. The actuator resets the original contact in the driver's lock, in response to which the remaining locks close / open with the use of the factory central lock.
    piotrek22101
    Help: 695
    Rate: 1421
    ? not D but A, I was corrected too.
    tzok
    Help: 3176
    Rate: 6549
    I can assure you that D ... diagram A is a diagram of internal connections of relays in the control unit, point 2 refers to the described situation, which refers to diagram D, which may not be very happily described as triggering with a plus (but indeed actuator is controlled by a switched plus, and the leaflet was written by Chinese)
    The aforementioned control with two pluses is scheme B and it refers to the control of the factory control unit, i.e. there are actuators in all doors and we connect, for example, to the close / open button on the console. In this case, only the control unit for the radio remote control is added and it only sends the closing / opening pulses to the factory lock control unit, and does not directly control any actuator.
    piotrek22101
    Help: 695
    Rate: 1421
    However, it is 100% the bottom left one.
  • #14 16353041
    kempes221
    IT WORKS !
    You are wonderful :D thank you very much for your help :D actually a very simple matter :) ) Best wishes :) )
The discussion revolves around connecting a universal central locking system to a 2004 Fiat Panda. The user seeks guidance on wiring the actuator and control unit for remote operation, as the existing setup only allows manual locking via the driver's key. Various responses clarify the wiring connections, emphasizing the importance of using the correct diagrams (specifically diagram A and D) for proper installation. Key instructions include connecting specific wires to the actuator and ensuring the control unit receives the correct power and ground signals. Ultimately, the user successfully implements the solution, confirming that the system works as intended.
