Hello, the problem is as follows: some time ago the central locking started to freak out, it closed, it opened when he wanted to, additionally the indicator light was on informing about the open driver's door. The first lead on the bank is the lock, the limit switch. I undressed the door, fastened a new lock and no change here, then the same. I connect the computer error 01331 driver's door control module (j386) too low power supply. There are two power supplies and after checking with a 12.4V meter on each, probably correct, after starting the car 14.2V. Weight ok, still the same error. I will add that pressing the buttons on the windows or mirrors sometimes works properly and sometimes they close and open the car, a bit strange. Whether the driver's door module or the comfort module should be to blame, I checked the cables, they are ok, unless I don't know about some, I will be grateful for your help.
autogaraz_galka
autogaraz_galka
Rate: 49
