Skoda Octavia I (2005) Alarm Disarming Issue with Logic Can System and Remote Control
Grzes133 6426 3
  • #1 16515968
    Grzes133
    Rate: 16
    Hello. The problem concerns Octavia I, 2005. with central locking with remote control and Logic Can alarm system. When I open the car with the remote control, it happens more and more often that the central locking opens correctly but the alarm does not disarm - and the LED blinks from the alarm, which leads to the situation that the alarm sounds until I press again once or more times on the remote control on the opening symbol, it will catch and disarm alarm goes off. It is the same when closing the central one, but sometimes I see through the car window that the alarm indicator does not flash, i.e. the alarm is not armed - pressing the remote control symbol on the remote control helps and arm the alarm. As if the alarm did not receive a signal from the central locking that the car was opened or closed. What could be the reason? Do I have to go to an electrician for alarms or is there an easy way to fix it?
  • #2 16516016
    Pawel wawa
    Help: 1262
    Rate: 4433
    You should physically check the connection of the alarm harness with the car.
  • #4 16521457
    Grzes133
    Rate: 16
    Maybe someone will need this information. I was at the electrician, he said that the alarm driver probably fell and you need to give it a rest and it is best to cut the alarm or he can find me and adjust a driver. So I tried one more thing, disconnected the battery for 10 minutes, reconnected it and so far it's fine. I don't know how long it helps, we'll see.
