Dacia 1.6 sce: Oil Change at 4,000 km or Wait for One-Year/15,000 km Mark?
brzuch0 15816 16
Should I change the oil in a Dacia 1.6 Sce at 4,000 km, or wait until the scheduled one-year or 15,000-km service?
Wait for the scheduled oil change at one year or 15,000 km rather than changing it at 4,000 km. One reply explicitly gives the interval as once per year or every 15,000 km, while another considers a 4,000-km change unnecessary. [#16505295] [#16504967] The 2016 Lodgy/Dokker 1.6 H4M is identified as a Nissan-derived engine, although earlier 1.6 K4M/K7M engines are Renault units. [#16510154] An early change around 1,000–2,000 km is an optional precaution some owners choose, not a requirement established by the thread. [#16505135] [#17531976] For warranty purposes, follow the manufacturer’s specified oil, filter, and service intervals or use an appropriately documented workshop. [#17532082]
  • #1 16504696
    brzuch0
    Help: 19
    Rate: 11
    My dacia is slowly approaching the course of 4,000 km. Now the question is to change the oil or wait for the planned exchange after a year or 15 thousand km?
    There is nothing on the subject in the book, but the website recommends exchange, but you know why $$$.
    The engine is a Nissan unit
  • #2 16504967
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    And what is written in the instruction manual. In my opinion, exchange oil after 4,000 is nonsense.
  • #3 16505135
    wichurewicz
    Help: 7
    Rate: 326
    In my name I exchanged after 1000 km of purchase, so-called zero review. The service did not push, they just said that there is a recommendation, and what I will do with it is my business. PLN 300 + another 180 for oil was not a high price compared to the cost of the entire car.
  • Manufacturer documents should override dealer advice
    #4 16505219
    mczapski
    Level 40  
    Help: 468
    Rate: 1660
    I guess it is not strange that those who live and exchanges will recommend exchanges every month. Do not be surprised, do not listen to the advice from the mangle. You have the manufacturer's documents and a certain DTC that are related to the warranty. The concept of reaching the car ceased to function thirty years back.
    But Nissan and Renault are one family in business so everything is possible.
  • #5 16505295
    milejow
    Help: 1563
    Rate: 5149
    In addition to the theme - the 1.6 (k4M or K7M) engine is Renault, not Nissan. As for the exchange of oil, as you write above, you do every year or every 15 thousand.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #6 16510154
    brzuch0
    Help: 19
    Rate: 11
    milejow wrote:
    In addition to the theme - the 1.6 (k4M or K7M) engine is a Renault unit, not Nissan.5 thousand.
    From 2016 in lodgy / dokker they assemble 1.6 H4M engines, so I think it is a construction engine from Nissan.
  • #7 16510910
    zed71
    Help: 13
    Rate: 185
    replace it will not hurt. The cost is small but calm ... invaluable. once the producers recommended replacing the first 1000-1500km because there are "post-production" filings in the oil. Now it's better and more accurate, but ... there's always something in oil. Anyway - you do not need to look at the manufacturer's recommendations - there is no interest for the cars not to break down. A lot of manufacturers recommends replacing every 30kkm and there are a lot of different ones (eg renault in a 1.5dc engine - after 100-150kkm the acetules are peeling).
  • #8 16510948
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    zed71 wrote:
    A lot of manufacturers recommend replacing every 30kkm
    While the original oils are pouring nothing is happening, worse when we buy fake or wrong.
    Or, even worse, we go for half-boules and 2km for ladybirds.
  • #9 16511033
    andrzej20001
    Help: 1578
    Rate: 6669
    Change and further exchanges do every 10-12 thousand. Buy oil in 1L bottles, top shelf filters.
  • Advocates daily oil changes as unnecessary overkill
    #10 16512937
    mczapski
    Level 40  
    Help: 468
    Rate: 1660
    A little more discussion and it will turn out that it's best to exchange oil every day. Even when you do not start the engine. Of course you will learn that it will not hurt. So maybe it also will not hurt to replace the car (for maintenance-free). And the car manufacturer is very much interested in a good opinion about the product. If this is not the case, the producer exposes himself to the costs of changes.
    Buying oil in 1 liter of packaging for exchange is another valuable idea.
  • #11 16512948
    andrzej20001
    Help: 1578
    Rate: 6669
    If you want to change every 30 I know it ends. With 1L packaging you can let go as you have a 100% reliable source.
  • Annual or 10–15k km oil changes are enough
    #12 16513670
    wichurewicz
    Help: 7
    Rate: 326
    The first one can be true for high-performance cars, and the second is for seasonal use. For an ordinary passenger car, in addition to a completely civil power unit, it is enough once a year or every 10-15 thousand kilometers. More often it's probably exaggeration and an excess of caution.
  • #13 17492688
    nosek86
    Rate: 21
    People ... I bought 4 years ago dokker 1.6 8v after 1000km I changed his oil, silently at home. What happened on the engine was pitch with filings! As in a 30letbim wreck! New oil and change every 15 thousand. I already have more than 100kkm and before the exchange the oil is always clean! The cost of an elfa 4litre is PLN 120 for me, works for 15 minutes ... Exchange or not? Ehh .... And then they do trash because it's fallen ...
  • #14 17531875
    mariusz324
    Did you buy the same filter as the original filter that you did not know? How is the warranty how will we do some service in the Dealership?
    Nar-Elektro
    Gożdzielin 105, Bodzechów, 27-420 | Tel.: 731XXXXXX (Show) | Company Website: www.nar-elektro.pl
  • #15 17531976
    kortyleski
    Help: 957
    Rate: 3860
    Service work, i.e. replacement of fluids and consumables, does not affect the warranty. Filter ... Mann, knecht, meyle. Oil, if not mobil or castrol from allegro for a few zeta. GM is quite cheap and does not really want to counterfeit it. I would exchange it after one thousand or two. And later, of course, according to his own concept, ie he had a ninth once a year or 15 thousand trip.
  • #16 17532082
    genek1000
    Help: 289
    Rate: 1057
    You can do such things alone silently between the survey values set by the manufacturer. If you do not do a review by manufacturer's recommendations, i.e. specification of oils, frequency of changing filters, etc. in the workshop, you can say goodbye to the warranty - item 4 of the general warranty conditions
    • OWG_DACIA_.pdf (133.89 KB) You must be logged in to download this attachment.
  • #17 17533672
    nosek86
    Rate: 21
    I bought the same filter - I have a store with parts .. for the filter wages PLN 12 in the ASO delete 40 ... oil by Specification with ELF and that's it. Traces have not been, besides, the belt is already guaranteed, almost 100kkm and while the pads in the front of the car are out of the car and it's a company car (as we know the best off-road is every company ...) guys her scorch for driving on customers, I was even in Paris ;-) (I do not recommend this route ... 14h with gas in the floor and at the maximum speed ...)
The discussion revolves around whether to change the oil in a Dacia vehicle with a 1.6 engine at 4,000 km or wait until the recommended interval of one year or 15,000 km. Opinions vary, with some users advocating for early oil changes due to potential contaminants from manufacturing, while others argue that following the manufacturer's guidelines is sufficient. The engine is identified as a Renault unit, with some confusion regarding its Nissan origins. Users emphasize the importance of using quality oil and filters to maintain engine health, suggesting that regular changes every 10,000 to 15,000 km are advisable for optimal performance.
