Oil Change Dilemma: Berlingo 1.6 HDi Diesel Box with 100Kkm, 12 Years – Citroen's Advice?
elektronikq 39561 9
Should I change the manual gearbox oil in a Citroën Berlingo 1.6 HDi after 100,000 km and 12 years, even though Citroën does not schedule it?
Citroën may not require a gearbox oil change according to the service schedule, but several replies say replacing the manual gearbox oil anyway is a good idea at this age and mileage [#17160272][#17175559][#18110803] One recommendation is 75W-80 oil, about 1.9 liters [#17175559] Another reply says the oil should be changed in all gearboxes and that manufacturers often omit the interval because they expect the car to be replaced after about 10 years or to need an expensive repair [#18110803] For the change, drain the old oil, then refill through the level screw/plug after removing the wheel; a hose and syringe are suggested for filling [#19820885][#19821021]
  • #1 17160247
    elektronikq
    Help: 70
    Rate: 614
    I have a dilemma about changing the oil in the manual gearbox. Driven over 100kkm, about 12 years.
    After visiting the site they told me that citroen does not order oil change in the gearbox.
    Has the oil not lost its parameters for such a long time? What do you think about changing the oil in the gearbox?
  • #2 17160257
    DriverMSG
    Help: 3984
    Rate: 4883
    There is no need.
  • #4 17160288
    elektronikq
    Help: 70
    Rate: 614
    link
    Here they say it's not a stupid idea.
  • #5 17175559
    elektronikq
    Help: 70
    Rate: 614
    The website recommends 75W-80 and 1.9 liters. greetings
    The website says that it is not exchangeable, but it can not be worse.
  • #6 18110803
    zwierzak5000
    Rate: 12
    I will dig a fossil out a bit (I'm just looking for information about the oil in the gearbox and coolant), but when I read "that the service does not provide for oil change in the gearbox" it is black blood flooding me.
    Of course, it must be replaced in all types of gearboxes. Not only in the machine, but also in the manual. In old cars, it is said how much to change oil. In new ones they don't give it anymore. The manufacturer does not assume oil change in the box, because it assumes that after 10 years we will buy a new car, or we will do a costly repair at an ASO.
  • #7 19820858
    maciobyk
    Rate: 16
    Refreshing the topic .... What oil (brand, parameters) should be used for this gearbox ???
  • #8 19820885
    zwierzak5000
    Rate: 12
    As they wrote before, the 75W80. I'm pouring LIQUI MOLY and it's fine. I recommend only a long tube and a syringe for replacement. Drain the old oil, then take off the wheel and there you have the screw from the level. Pour there with a hose and a syringe.
  • #9 19821013
    maciobyk1984
    Is the drain plug visible too?
  • #10 19821021
    zwierzak5000
    Rate: 12
    The screw is visible from the bottom. When you take the cover off you will surely see it. :)
The discussion revolves around the necessity of changing the oil in the manual gearbox of a Citroen Berlingo 1.6 HDi Diesel, which has been driven for over 100,000 km and is 12 years old. While Citroen's official stance is that oil changes in the gearbox are not required, several participants argue that it is beneficial to change the oil to maintain gearbox performance. Recommendations include using 75W-80 oil, with a specific mention of LIQUI MOLY as a suitable brand. Participants also discuss the practical aspects of changing the oil, including the use of a syringe for pouring and locating the drain plug.
