Renault Scenic 1.6 (2001): Identifying Previous Oil Type or Opting for Complete Oil Change
marek19_70 49497 9
How can I find out what engine oil was previously used in my 2001 Renault Scenic 1.6, or should I just replace it?
If you cannot find any record of the previous oil, the safest option is to change the oil and filter completely. First look for a bottle in the trunk, a sticker on the door pillar, or notes under the hood; if nothing is there, replace the oil. [#11270185] The thread also says oils are generally miscible, so a small top-up with another oil should not cause trouble, but the filter should still be changed. [#11270211] Since the car has an unknown history and no service documents, one reply recommends replacing all belts and fluids as well. [#11270811]
  • #1 11270037
    marek19_70
    Hello! I bought a Renault scenic 1.6 from 2001. Unfortunately, I don't know what oil was poured in earlier. Is there any way to check this or should I change the oil completely? Please help!
  • #2 11270185
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Look for a bottle in the trunk, a sticker on the pillar between the doors, or notes under the hood.
    If nothing is found, the oil needs to be changed.
  • #3 11270211
    robertmaciej
    Theoretically, all oils are miscible, so in the case of a (small) refill, nothing can happen, but you will not miss the replacement, of course, remember about the oil filter - it costs 20 zlotys.
  • #4 11270811
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    Hello, after buying a car with an unknown past (no original service book and, above all, no bills), I would recommend that you replace all belts and body fluids of the car immediately, because NOBODY does it when planning to sell the car!
  • #5 11270864
    lukkii
    Help: 9
    Rate: 134
    robertmaciej wrote:
    In theory, virtually all oils are miscible
    If you have a mineral car in your car, let it be synthetic. - engine to be replaced. If you don't find any sticker, it is safest to pour semi-synthetic.
  • #6 11270940
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Why to replace the engine? What will happen to him? (Answer with the facts - not that someone .. sometime ...)
  • #7 11270961
    xyro
    Help: 47
    Rate: 238
    If you have a mineral car in your car, let's pour a synthetics-engine to be replaced
    As he will pour water instead of oil it too ;)
    Such myths come from the times of polonaises and toddlers ... We pour the oil we can afford. If the car is to serve longer, it's just a synthetic. If we like to change the car every 2-3 years, such an unstrained petrol 1.6 and it will go on agrol and there will be no major problems. We pour oil that meets the manufacturer's standards, and this can be easily checked. If a car is in great condition, it does not take oil and, most of all, we can afford to maintain it, we pour synthetic and change every 10-15 thousand. If the engine is already old and limp, it is only cheap mineral oil that needs to be added anyway. Because semi-synthetics are actually enriched minerals, and 80% of synthetics are enriched semi-synthetics.
    You can pour 10w40 from a good company into this car in the dark and it will be a git, unless you keep the car until its death, you can try a synthetic. Nothing will happen to the mineral one, it is important to change the oil and filter in time.
    PS: I admire people who, when changing, for example, the gaskets under the bowl, tell me to pour the old oil into the engine ;)
  • #8 11270964
    lukkii
    Help: 9
    Rate: 134
    Because the synthetic will dissolve all the muck deposits, which will remain after the old mineral. And I will not prove it to you, I only advise you. I can take a picture of the Nissan Primiery 2.0 engine, seized, sent to you and seized after such an oil change.
  • #9 11271020
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    The bowl can be unscrewed and cleaned.
    You don't have to send me photos.
    I saw the Mazda 2.0V6 engine - the idiot advised to pour 15W40 - after 20 thousand there was nothing to repair.
    Fiat Ducato 2.5 TDI - 500.000km mileage - only 5W40 cast oil - no oil drips.
    These are examples from my practice, I can list them for a long time.
    15W40 is a slow engine killer but if you prefer .....
    And one more story - Audi 1.9 TDI PD - oil change in the workshop - Lady - you have a leak
    You ask what can be done with it?
    Workshop - we will pour 15W40, it will silt up and there will be no leakage.
    I was crying with laughter when she told me this - I replaced the simering, the oil with the right one and it's ok.
  • #10 11271180
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    The times of Selektol and carbon deposits are gone forever. In a regularly and properly serviced engine there are no carbon deposits - unless the car was bought from Turas or imported from France where they do not know what an oil change is - they only make refills
The discussion revolves around a Renault Scenic 1.6 from 2001, with the main concern being the uncertainty of the previous oil type used. Suggestions include checking for any oil-related documentation in the trunk or under the hood. If no information is found, a complete oil change is recommended. Participants note that while all oils are theoretically miscible, it is safer to switch to semi-synthetic oil if the previous type is unknown. They emphasize the importance of changing all fluids and belts when acquiring a used vehicle. Concerns about synthetic oils dissolving deposits from older mineral oils are raised, with some advocating for synthetic oil for better engine longevity, while others suggest using mineral oil for older engines. The consensus leans towards changing the oil and filter to ensure optimal engine performance.
