Looking for Online Retailers Selling Fuel Mixture Adjustment Screw for NAC/LIDER Brushcutter
artekideapop 6741 9
Can I buy an online fuel mixture adjustment screw for a NAC/LIDER brushcutter carburetor?
Probably not as a standalone part; the thread suggests searching for a carburetor repair kit for the exact carburetor type, such as Zama or Walbro, instead of the screw itself [#16505984][#16507319] If the screw is missing, the practical workaround is to buy a used carburetor cheaply and salvage the screw from it [#16509267] Another reply says that in practice you will either need a new carburetor or just hope to find the screw by chance [#16535194]
  • #1 16505713
    artekideapop
    Rate: 105
    Will I buy a screw to adjust the fuel mixture composition somewhere on the Internet for the carburetor of the NAC or LIDER brush cutter ??
  • #2 16505866
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Hmm, and they don't have the company website ??
  • #3 16505984
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    What is the Zama carburetor there; Walbro. Search for Carburetor Repair Kit under the name.
  • #4 16507319
    artekideapop
    Rate: 105
    There are some repair kits, but I will not find the screw itself.
  • #5 16509255
    pawel_amatorek
    Rate: 74
    What happened to the screw? Has it broken or has it worked?
  • #6 16509267
    citromaniak
    Help: 53
    Rate: 394
    Search for a used carburetor for pennies and screw it out, cost the same as a new screw.
  • #7 16509274
    pawel_amatorek
    Rate: 74
    Buddy, it is not always as you write, it may turn out that he will get the adjustment screw for PLN 5 and the carburetor for PLN 40-50
  • #8 16509294
    artekideapop
    Rate: 105
    pawel_amatorek wrote:
    What happened to the screw? cracked or broken?
    Dad got a brushcutter from someone and the carburetor screw is missing. And especially buying the entire carburetor is pointless.
  • #9 16509295
    citromaniak
    Help: 53
    Rate: 394
    What's free of charge?
    A new carburetor for PLN 30, and what to say, used, a shipment worth more than this screw.
  • #10 16535194
    artekideapop
    Rate: 105
    Probably none of that. Either a new carburetor or somewhere by accident I find a screw.
The discussion revolves around finding an online retailer for a fuel mixture adjustment screw for the NAC or LIDER brushcutter's carburetor. Users suggest searching for carburetor repair kits, specifically mentioning Zama and Walbro carburetors. Some participants propose looking for a used carburetor to salvage the screw, while others note that purchasing a new carburetor may be more cost-effective than searching for the individual screw. The original poster clarifies that the screw is missing from a brushcutter acquired from someone else, making the purchase of a complete carburetor unnecessary.
