Connecting LG GT540 (CyanogenMod 7.2.0, Android 2.3.7) & HTC One M7 via VNC for Remote Control
tczt 5091 5
  • #1 16508296
    tczt
    Hi! I would like to connect two smartphones with a network so that I can remotely control one of them. In this case, the controlled smartphone would be a rooted LG GT540 on CyanogenMod 7.2.0, version android 2.3.7. The controlling smartphone is to be HTC One m7 on the original system and without root.
    I have installed the VNC server droid on LG and VNC Viewer on HTC. And it works, the HTC screen displays the LG screen and I can control it freely, but only when I have both smartphones connected to the same wifi network. If I turn off wifi on HTC and turn on cellular transfer, phones disconnect and cannot be connected this way. What am I doing wrong?
  • #2 16508304
    jimasek
    Help: 3783
    Rate: 2681
    Through wifi, devices get on one subnet. This is no longer the case with cellular data.
  • #3 16508310
    tczt
    But what do I have to do to be able to remotely control the device when it is on another network? I would like to leave one phone at home and go out with the other, having access to the phone that is left at home.
    jimasek
    Help: 3783
    Rate: 2681
    Use a VPN (virtual network) or use another program that allows you to connect via the cellular network (proxy server).
    wampirek
    Help: 17
    Rate: 12
    Alternatively, you can connect hamachi calls via VPN as your friend said.
  • #6 16511678
    tczt
    Thanks a lot, guys. I used hamachi, and connected my phones with a VPN.
    Problem solved, topic to be closed. :)
