Citroen C4 Picasso 2007 - Blower does not work, mixing flaps do not react
krystek86 9597 1
  • #1 16508849
    krystek86
    Rate: 30
    Hello! a customer came Citroen C4 Picasso from 2007 2.0 HDI car had a semi-automatic or remanufactured gearbox exchanged alone could not determine it.
    And since then problems with the car began to happen.
    The first was the lack of support for the meter and the lock pilot after closing could not be opened, only with the key, but the problem was the BSI jumper set for parking and not client.
    The second problem is the relay from the starter is omitted by another relay and the mileage traveled 45000km after reading from Lexia the fact is that BSI was buried but this is not a problem auto smokes. BSM was unskillfully open or could not be opened at all.
    The third problem is the blower not working and the hatches in the tunnels do not work. On the computer in the parameter view, all buttons work, the values change. When testing the components, you can control everything with a blower flap. The guy brought the air conditioning controller which is behind the storage compartment and the electronic resistance that was replaced.
    I do not have diagrams for this model, maybe someone would lead me because my hands are falling as soon as I will need dunks from parts, I can share maybe there is something dug up.
    Thank you in advance for your interest
