VOLVO S40 1.9 Diesel 1999 Engine Shuts Off While Driving: Causes and Solutions for Error 4411
chris1991p 10962 8
  • #1 16509287
    chris1991p
    Hey,
    I have a problem with the Volvo S40 1.9 Disel 1999.
    For some time the car goes out while driving, the engine stops working, it doesn't matter:
    - turnover height,
    - this happens both at ease and in running,
    -speed,
    - I'm going straight, up or down, going out.
    Most often I have no problems firing the car immediately (50 times, as it happened to me, maybe 5 times did not start immediately just after pulling out and putting the key back to the ignition), although if I do not wait about 5 minutes, after a few kilometers it goes out again.
    Initially, I thought that maybe the mechanic had changed the fuel filter and connected it to the computer, two errors appeared:
    4423 - Discontinuous Immobilizer
    4411 - discontinuous fuel cut off
    deleted them, and drove a few kilometers went out again. after reconnecting to the computer, only an error popped up
    And here is my question
    What could it be? Has any of you happened?
  • #2 16511051
    ignacent
    Rate: 11
    First of all, check the tightness of the fuel system - manual pump at the fuel filter, return lines from injections, injections only, injection pump - there likes to be leaking
    Secondly, check the sagging of the dragon on the fuel pump in the tank
  • #3 16511196
    ftp.kowal
    Level 36  
    Help: 331
    Rate: 1844
    What fuel pump in the tank? Start the car and move the bundle of wires going to the injection pump.
  • #4 16511214
    ignacent
    Rate: 11
    Normal pump that is in the tank
  • #5 16511219
    ftp.kowal
    Level 36  
    Help: 331
    Rate: 1844
    There is no pump there.
  • #7 16511703
    marfur30
    Help: 138
    Rate: 386
    ignacent wrote:
    And this is strange, what is then located on the rear sofa
    / foto borrowed from the volvo forum /
    [IMG] http://i1.fmix.pl/fmi448/f0237ad60013d5845933f383 [/ IMG]
    Fuel level float, supply line and excess fuel.
    As for the fault, either the damaged harness to the quenching solenoid valve or the solenoid valve to be replaced.
  • #8 16512302
    chris1991p
    Ok thanks for the answers :) The fuel system is ok, the immobilizer is to blame :)
  • #9 17301631
    Kaziumoto
    Rate: 11
    Hello. I have identical symptoms in the xc90 car goes out regardless of the conditions sometimes it is rare that I have to pull in to insert the keys. I went to two electricians and they told me that it can't be immo because immo won't turn off the car while driving. There are no errors. Injections and the whole installation are checked and nothing. The car sometimes goes out. My question is / what was wrong with the immo that was turning off your engine? How did you fix it?
The discussion revolves around a 1999 Volvo S40 1.9 Diesel experiencing engine shutdowns while driving, regardless of conditions such as speed or incline. The user reports intermittent issues with restarting the engine and mentions error codes 4423 (Discontinuous Immobilizer) and 4411 (Discontinuous Fuel Cut Off). Responses suggest checking the fuel system's integrity, including the manual pump, return lines, and potential issues with the wiring harness to the solenoid valve. One user notes similar symptoms in a Volvo XC90, questioning the immobilizer's role in engine shutdowns. The original poster concludes that the fuel system is functioning properly and suspects the immobilizer as the cause.
