VOLVO S40 1.8 '98 Fails to Start - Fuel Pump, Engine Spin, and Immobilizer Antenna Issues
adi25110 15960 8
  • #1 16825209
    adi25110
    Hello. I am the lucky owner of VOLVO S40 1.8 '98. My problem is that the car won't start. Earlier, after turning the key, something like a howling sound for a second was heard, as if the pump sucked in fuel, now it is gone. I left my car in the parking lot in the morning and started in the afternoon and went out after a second. Then he didn't fire again. The engine spins, but I don't want to start. The fuel pump is operational. I didn't check the spark. I will add that I changed the antenna of the immobilizer. I am asking for help with hints and suggestions, I am completely green and I am just learning. Greetings.
  • #2 16825423
    leonek4
    Help: 104
    Rate: 638
    Would it be best to do computer diagnostics? How does the immo control behave?
  • #3 16826127
    Cysiek89
    Rate: 39
    Is the imo light off? and check the spark because there may be a problem with the shaft sensor.
  • #4 16826201
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    adi25110 wrote:
    Hello. I am the lucky owner of VOLVO S40 1.8 '98. My problem is that the car won't start. I suspect the injection pump because after turning the key can not hear it. I left my phone normally in the morning and in the afternoon it fired and after a second it went out
    Normally you can write it, what does the injection pump have in common with the gasoline engine and the phone going out?
  • #5 16826317
    leonek4
    Help: 104
    Rate: 638
    Check if there is a spark.
  • #6 16826323
    adi25110
    The immo indicator behaves normally and goes out after a while.
    Sorry for the mistakes, dictionary.
  • #7 16826355
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    Small offtopic. It seems to me that before starting the topic should be a small test of technical knowledge. After all, advising someone on such topics is completely pointless ... It's like logging into a gastronomic forum and writing a post: "after 2 hours of cooking, I took out raw meat, what's the problem? I checked that I had electricity at home, but I didn't check the oven is heating up. "
    And that it would be in accordance with the regulations. Connect the computer and see if you can see the speed and whether you have any connection with the engine control.
  • #8 16826381
    adi25110
    I don't understand your answer. Could you develop
  • #9 16826603
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    Looking for help in the forum, and you have done practically nothing to solve the problem.
    But I understand that you expect professional help, so:
    - Use an oscilloscope to check the shaft and shaft position sensor including the harnesses, under load and short-circuit angle
    - check motor controller power supply, permanent and main relay
    - check the fuel pump relay and its control
The discussion revolves around a 1998 Volvo S40 1.8 that fails to start despite the engine spinning. The owner reports a previous howling sound from the fuel pump, which has since ceased. The fuel pump is confirmed operational, but the spark has not been checked. The immobilizer antenna has been replaced, and the immobilizer indicator behaves normally. Responses suggest performing computer diagnostics, checking for spark, and examining the shaft position sensor, motor controller power supply, and relays related to the fuel pump and engine control. There is a call for a more thorough technical assessment before seeking help.
