Cyfrowy Polsat, is the strength and quality of the signal, no picture. An unusua
salieri0 15393 8
  • Professional meter found usable satellite signal spots
    #1 16511900
    salieri0
    I've been struggling with the problem for 4 weeks.
    Four weeks ago, after returning to my holiday home after the break, I first connected the TV set-top box and I had the 60 [bowl] strength of 75, the quality of 65 received nice and even enough HD channels.
    Three weeks ago, the picture began to "shred", the signal was unstable, that is, despite the windless, sunny weather, the signal on the menu preview was behaving:
    * 20 seconds - strength 75 quality 65, then for a moment it dropped to the level of force 30 quality 0 and ... no signal, in a moment the signal returned and so repeated every few seconds.
    Attempts to improve ended with a maximum-optimal return to the state as above
    Two weeks ago, I took up the antenna re-setting on the meter, including the pointer and replacement of the converter with a new one. Unfortunately, this attempt was burnt. ATTENTION!!! - no picture, even though according to the meter it should already be flown.
    Three weeks ago, seeing what was a week earlier, I bought a new thick cable and a 90cm bowl and repeated the activities from before a week, so I checked again by connecting the antenna on HD5000, HD3000 and Globo set-top boxes. Here only on the Globo decoder and the start of searching for HotBird - it showed me the strength of 75% quality 0, while on Polsat decoders 0 and 0 without traffic.
    A little resigned I took into account the trees opposite the antenna, a new thicker and factory-made cable, a new larger canopy, a new façade handle, all risers, a horizontal pattern, and results are still missing. In this moment, even though I have done many activities from the so-called amateur primer ;-) , I decided to call someone who would look for signals with a professional meter.
    Today, I was with the man from the morning [a fitter with experience]: - / who came with a meter with whom he walked with me all over the area, and actually found two places where he hit with strength 72% and quality 78. I already thought that the topic I have averted nothing more wrong, after installing the plate on the roof of the house and removing the cable to the decoder, it turned out that the HD5000 decoder is 0 and 0 and no image, but on the Nat Geo channel is 76 and quality 65 [I got stupid], connected the GLOBO decoder and there with turn only on channel 4funTV was strength 70 and quality 65, and the rest 0 and 0, but still no image even on 4funtv. The fitter informed me that he appeared to find a signal and that his role ended, he started telling me that both decoders are damaged or something like that, that it's the fault of configuration factors, etc, etc. that I call myself to Technical Support. Of course, to prove to him that this is not the problem, I went to the neighbor after C + and after connecting also 0 and 0, so you said that C + is some "other" that it is worse, etc. etc. Although I told him that I had six months ago and C + and Polsat only switched the cable and everything sounded as it should. ;-(
    No picture and so much in the subject + still questionable antenna setting - I think ...
    I am asking you for help, thank you in advance for all who will try to get interested in this problem for a moment.
    I'm from Lodz, the problem location is in Ludowinka [gm. Wodzierady]
  • #2 16512117
    LeDy
    Help: 1990
    Rate: 2938
    I do not believe what you write. Call a normal person who has an idea of what and how to set up. I have repeatedly written about the influence of trees, so just search and read.
    You are not struggling with the problem and you are just pretending.
    Pay it as soon as it proves you are receiving.
  • #3 16512150
    salieri0
    Fact, the next one will get money as the picture will be :-) and now it seems to me that just something wrong with the setting on his side, only why on Nat Geo is strength and quality it surprises me, and on the other 0 and 0.
    Thanks greetings.
  • Installer lacks knowledge despite meter showing signal
    #4 16513093
    _kli_
    Help: 760
    Rate: 1038
    salieri0 wrote:
    [a fitter with experience]: - / who came with the meter
    salieri0 wrote:
    The fitter informed me that he appeared to find a signal and that's where his role ends, he started telling me that both decoders are damaged or something like that, that it's the fault of configuration factors, etc, etc. that I call myself in Polsat Technical support
    salieri0 wrote:
    The Lord said that C + is some "other" that he is worse
    Change the installer, because he has no knowledge or experience :!:
    salieri0 wrote:
    no picture, even though according to the meter it should already be flying.
    No picture or no signal? Do you have any messages on the TV screen?
  • #5 16515881
    salieri0
    On the HD 5000 Polsat decoder in the place where the Net Geo channel is located, strength 76 and quality 65 [on the channel control screen], and the rest of the Hotbird channels is on the screen "No signal from the antenna check the antenna connection", while on 4funtv on the decoder globo is strength is quality but no image.
    I think I do not know you as much as you did, but could the meter which he had been able to break, i.e. it was actually set up on a hotbird and showed strength and power, and as a result it was "fake" ???
  • #6 16515901
    Kenworth 18
    Help: 2442
    Rate: 3749
    It turns out that the antenna is not set to Hot Bird 13E only for Sirius, for example.
    Of course, this is just my hypothesis and I can be wrong.
  • #7 16515909
    LeDy
    Help: 1990
    Rate: 2938
    salieri0 wrote:
    I think I do not know you like you .
    Are you kidding yourself with this thinking?
    If you had a bit of a concept then you would not assume a topic and would not write about it as a specialist and you would do it yourself.
  • #8 16515981
    salieri0
    Okay, you can not believe me - but instead of writing about the topic, you just make fun of empty posts trying to moralize me, if you do not have anything constructive to say, do not say anything.
    If you try to help me like this then I am not surprised that you have over 10,000 posts
    good night, even if you have the power to remove this entry.
    Moderated By telesat1:
    3.1.9. Do not be ironic and do not be mean to the other side of the discussion. Respect different opinions and other opinions on the forum.
  • #9 16517217
The discussion revolves around a user experiencing signal issues with their Cyfrowy Polsat TV set-top box after returning to their holiday home. Initially, the signal strength was adequate, but it deteriorated over time, leading to intermittent picture quality and eventual loss of signal. The user attempted to troubleshoot by resetting the antenna and replacing the converter, but these efforts were unsuccessful. Other participants suggested that the antenna might be misaligned or that the installer lacked the necessary expertise. There were also speculations about the signal meter potentially being set incorrectly. The conversation highlights the importance of proper antenna alignment and installation for reliable signal reception.
