Cyfrowy Polsat Missing Channels: Signal Issues, LNB Input & Antenna Connection Troubleshooting
McPrzemzi 158304 9
Why do only the Polsat channels disappear on Cyfrowy Polsat and show “Check the connection and signal to the LNB input,” even though the other channels work?
The missing Polsat channels are most likely caused by the LNB/converter, cable connections, or signal quality on that specific transponder, even if other channels still work [#17049386][#17049328][#17050149] On the problem channel, press and hold the red button on the remote to display strength, quality, and MER, then compare those values with TVP-1 HD and TVP-2 HD [#17050732] Check how many places the coax cable is connected and whether the connectors are in good condition [#17050149] If needed, turn the converter/LNB on the antenna or replace it; one reply says a faulty converter caused the same kind of problem twice [#17049386][#17050149] A factory reset and channel re-scan was also suggested, but the main thing is to verify the LNB/cable and the signal readings on the affected channels [#17049386][#17050732]
  • #1 17049293
    McPrzemzi
    Rate: 13
    Hello, I have a problem with Cyfrowy Polsat. He writes that "Check the connection and signal to the LNB input" all channels operate in addition to this Polsat (ordinary, hd, polsat sport, news, ...) sometimes it is so that it works but rarely. Do you know maybe What is the reason to prevent it, what to do or whether to enter the antenna anyway or what greet ??
    Let me remind you that at the point of Cyfrowy Polsat they checked the decoder and the pict. I do not know but a satellite dish (plate).
  • #2 17049324
    olador
    Level 37  
    Help: 429
    Rate: 1447
    What is the strength and quality of the signal?
  • #3 17049328
    mosikjerry
    Rate: 18
    Maybe a problem in connecting the wires?
  • #4 17049348
    McPrzemzi
    Rate: 13
    85% strength and quality.
    I do not know the wires because all other channels except polsat works.
    And a converter or something like that maybe a problem (I do not know if I wrote it well, but it's about what's on the satellite)
  • #5 17049386
    olador
    Level 37  
    Help: 429
    Rate: 1447
    There may be a problem with the converter, I had a case twice.
    I suggest to go back to factory settings and re-upload channels ...
  • #6 17050149
  • #7 17050732
    LeDy
    Help: 1987
    Rate: 2927
    On the channel you do not answer, press and hold the red button on the remote control and after a while you will see strength, quality, MER. Enter how much you have and also TVP-1HD and TVP-2HD ..
  • #8 17066404
    pasikonik5
    Rate: 65
    what decoder model?
    what software version?
  • #9 17066526
  • #10 17066596
    pasikonik5
    Rate: 65
    mihal2002 wrote:
    pasikonik5 wrote:
    what decoder model?
    You can see in the picture.
    Well, as I increased it I see that hd2000 or hd3000. At first I saw Evobox at the bottom of the cabinet, something white is lying there. I thought maybe a Unicable converter was running instead of a universal one
✨ The discussion revolves around signal issues with Cyfrowy Polsat, specifically the error message "Check the connection and signal to the LNB input." The user reports that all channels except Polsat (including HD and sports channels) are functioning intermittently. Responses suggest checking the signal strength and quality, which is reported at 85%. Potential causes include faulty wiring, issues with the LNB converter, or the need to reset the decoder to factory settings. The conversation also touches on the decoder model, with mentions of HD2000, HD3000, and Evobox, and the possibility of using a Unicable converter instead of a universal one.
