Remote-Controlled Miniature Circuit Breaker: On/Off Switch with WiFi or Bluetooth Options
barnio 6372 8
  • #1 16511986
    barnio
    Rate: 25
    The question is, are there any remote-controlled miniature circuit breakers? I mean the ability to remotely turn on and off such a switch.
    Basically any control method, it can be a remote control, it can be a smartphone with WIFi or Bluetooth.
    Raphael
  • #2 16511998
    Zbigniew 400
    Help: 283
    Rate: 794
    For what ? It is enough to put a remote-controlled switch in series.
  • MCBs are not meant for frequent remote switching
    #3 16512031
    retrofood
    Help: 1140
    Rate: 4800
    There is and will not be. The overcurrent circuit breakers are not devices designed for frequent switching. In addition, after their activation, you should determine the cause of their operation, and do not play with wireless communication.
  • #4 16512039
    barnio
    Rate: 25
    I would like to avoid the switch in series, I would prefer to replace the overcurrent switch I have on the strip with a remotely controlled one.
  • #5 16512064
    Wojciech.
    Level 37  
    Help: 319
    Rate: 467
    But what is this circuit breaker all about? You can not give a contactor or relay, for example?
  • #6 16512427
    Zbigniew 400
    Help: 283
    Rate: 794
    How do you replace it to protect this circuit?
  • #7 16512441
    karolark
    Help: 702
    Rate: 2519
    The fuse in series with him is a general idea from the series .............
  • #8 16512473
    haneb
    Help: 61
    Rate: 214
    Maybe remote controlled sockets?
  • #9 16512477
    retrofood
    Help: 1140
    Rate: 4800
    I close. Hyde Park genre theme.
The discussion centers around the feasibility of remote-controlled miniature circuit breakers that can be operated via WiFi or Bluetooth. Users express skepticism about the practicality of such devices, noting that traditional overcurrent circuit breakers are not designed for frequent switching and emphasize the importance of identifying the cause of any circuit interruption. Alternatives such as remote-controlled switches in series or remote-controlled sockets are suggested, but there is a consensus that replacing an overcurrent switch with a remote-controlled version may not be advisable due to safety concerns.
