Where can I find modules/plugs for single-pole overcurrent circuit breakers?
boe6666 1311 13
Can I buy an add-on module for a single-pole circuit breaker that lets me monitor its state and remotely switch it on and off?
Look for breaker accessories called auxiliary contacts, voltage trip units, and motor operating devices; they are mounted next to the circuit breaker and use a lever or metal rod to mechanically interact with the breaker handle [#17690475][#17690471] The thread gives examples such as an older F&G/Eaton-style accessory and ABB’s S2C-CM1 motor-operating device [#17693296][#17694173] If you only need status feedback, a phase-presence or voltage-monitoring module can be used instead of a mechanical position sensor [#17693304]
  • #1 17690407
    boe6666
    Rate: 20
    Hello all.
    I have a question i.e. Are there any modules/capacitors for single-pole simplest overcurrent circuit breakers ?
    I am concerned with monitoring the status of such circuit breakers while in the "second iteration" being able to control them (on/off).
    Such overlays/modules would make it possible to control circuits and determine their state from the level of home automation systems, without the need to install bistable relays/contactors.
    I have been looking for such components for some time but somehow cannot find them.
    In principle, the way I see it is that:
    - mounted "on top" of the switch with an extension "handle" for manual control
    - 2 limit switches (or optical sensors) of the actual position
    - 2 electromagnetic pins (tiny ones) to control the "handle" of the switch
    - optional - coil for measuring the current in the circuit.
    The whole thing either connected by cable to the automation system or, for example, via an ESP module (wifi).
    Anyone perhaps familiar with such solutions ?
  • #2 17690471
    juan cabrillo
    Help: 127
    Rate: 242
    Type "auxiliary contact" into your goggle. Almost every accessory manufacturer has this on offer.
  • #3 17690475
    Plumpi
    Heating systems specialist
    Help: 874
    Rate: 2674
    boe6666 wrote:
    Hello everyone.
    I mean monitoring the status of such circuit breakers while in the "second iteration" being able to control them (on/off).
    Such recorders/modules would enable circuits to be controlled and their status determined from the level of home automation systems, without the need to install bistable relays/contactors.
    There are so-called NO/NC auxiliary contacts and voltage tripping devices for tripping overcurrent circuit breakers, which are mounted next to the circuit breaker. They have a lever and a metal stick that mechanically connects the circuit breaker lever to the auxiliary contact lever or the trip.
    Voltage triggers come in two types as rise and fade.
    Auxiliary contacts as well as triggers are often used in industrial automation systems.
    But I have not heard of switching devices.
  • #4 17690521
    boe6666
    Rate: 20
    Thanks for the reply, I'll keep looking. It's a pity there are no such devices - you could easily incorporate existing switchgear and circuits into control systems....
  • #5 17690531
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    There are automatic switches including auxiliary contacts. I have seen such in BTSs.
    Unfortunately I can't remember which company they were. Mounted next to the overcurrent switch with a pin that lifted the latch upwards.
  • #7 17691178
    CYRUS2
    Help: 1241
    Rate: 3530
    boe6666 wrote:
    Thanks for the reply, I'll keep looking. It's a pity there are no such devices - it would be easy to incorporate existing switchgear and circuits into control systems....
    Contactor, relay can't ?
    Monitoring by means of free contacts.
    Or with systems that monitor the voltage at the outputs.
    I did it on the INTEGRA control panel.
  • #8 17692577
    blady1k9
    As CYRUS2's colleague writes - the overcurrent circuit breaker is not for this.
    A situation may arise where you try to re-connect a circuit in which there is a short circuit.
    It is better to use a relay/contactor.
  • #9 17693242
    boe6666
    Rate: 20
    Activation of the overcurrent circuit breaker in the event of a short circuit is impossible. Contactors and relays are ok but there is not always room. In addition, this is a rather expensive solution for bistable.
  • #11 17693304
    raffin
    Help: 86
    Rate: 109
    boe6666 wrote:
    - 2 limiters (or optical sensors) of the actual position
    Instead of "observing" the position of the lever, you can test the voltage in the circuit. I sometimes use such "phase presence controllers" from Ropam for control panels, even works well: https://ropam.com.pl/pl/towar/580/pmt.html galvanic separation of sides on optocoupler. The cost is ridiculous, about ~PLN19
    Shadowix
    Help: 191
    Rate: 268
    boe6666 wrote:
    Such circuit breakers/modules would enable control of circuits
    People, finally understand that an overcurrent circuit breaker is not for switching or switching circuits but for protecting them!
    Relays and contactors are for control!
    Don't mix up overcurrent triggers, as they also have a different role on the net....
    boe6666 wrote:
    there is not always room. Furthermore, it is quite an expensive solution
    Such austerity only breeds further problems; it is better to get down to something decent and ethical straight away.
  • #13 17693531
    CYRUS2
    Help: 1241
    Rate: 3530
    This takes up the least amount of space.
    If you don't have space for it, you won't do anything.
  • #14 17694173
    boe6666
    Rate: 20
    And who is talking about control? after all, we are not going to argue about nomenclature. An overcurrent circuit breaker has a "handle" and therefore allows the circuit to be switched on and off - it has been so designed, tested and verified.
    Personally, I imagine a building that has a P/T installation and a switchboard that is already "full". In such a situation there is no possibility of simply fitting relays or contactors. Such overlays would allow circuits to be switched off and on without interfering with the switchgear.
    I found something like this: https://new.abb.com/products/2CSS201997R0013/s2c-cm1-motor-operating-device
The discussion addresses the availability and feasibility of modules or auxiliary devices for single-pole overcurrent circuit breakers that enable status monitoring and remote control (on/off) without installing additional bistable relays or contactors. Auxiliary contacts (NO/NC) and voltage tripping devices are commonly used accessories mounted alongside circuit breakers to indicate breaker position or trip status, often employed in industrial automation. However, devices capable of actively switching the breaker remotely are rare or nonexistent. Some users suggest using contactors or relays for switching, but these require additional space and cost, which may not be feasible in compact switchboards. Alternatives include motor operating devices designed to mechanically operate breakers, such as the ABB S2C-CM1 motor operating device. Voltage presence detectors like Ropam’s phase presence controllers with galvanic isolation can monitor circuit status without mechanical intervention. The consensus emphasizes that overcurrent breakers are primarily protective devices, not intended for switching control, and that relays/contactors remain the standard for circuit control despite space and cost challenges.
