Oil Change Guide: Daelim VC 125f - Locating and Replacing Oil Filter
tomasz9920 8280 2
  • #1 16512494
    tomasz9920
    Rate: 33
    Hello, I'm going to change the oil in the Daelim VC 125f, but I do not know where the oil filter is located, from what I know this oil filter is in this motorcycle. I will be grateful for your help, best regards.
  • #2 16513496
    BANANvanDYK
    Help: 1167
    Rate: 2602
    On the right, on the clutch cover there should be a small cover, under it there should be a filter.
    When adding oil, remember that just like in Hondach, you do not screw in a measuring tape, just insert and remove.
  • #3 16515024
    tomasz9920
    Rate: 33
    Thank you for your help, I'm closing the topic
