Hyundai i40 1.7 CRDi Fuel Filter Replacement: Step-by-Step Guide & Sequence of Actions
znaniecki 50223 7
  • #1 15723978
    znaniecki
    Rate: 22
    Has anyone replaced the fuel filter in the hyundai i40, I need to replace it and I do not know how to go about it, I mean the sequence of actions
  • Fuel filter replacement and bleeding procedure depends on access and pump setup
    #2 15724018
    rafal.jaro
    VAG group specialist
    Help: 164
    Rate: 1047
    Nothing complicated, if you have access to unscrew the filter on the car, you normally unscrew it and screw in a new one. If you have a pump in the tank, you turn the ignition a dozen times to pump the fuel into the filter, start the car and it's ready. Worse, when there is no access to do it on the car, then you have to unscrew the base to which the filter is screwed in, disconnect the cubes from the sensors, remove the fuel hoses (mark where it was) and do it on the table. If there is no pump in the tank, you will need a computer and software venting.
  • #3 15724455
    znaniecki
    Rate: 22
    I meant more about how to get to the filter because it is covered by the battery and the computer
  • #4 15724822
    rafal.jaro
    Help: 164
    Rate: 1047
    The easiest way is to remove the battery.
  • #5 15725503
    znaniecki
    Rate: 22
    What about disconnecting the computer and taking it out too?
  • #6 15725798
    rafal.jaro
    Help: 164
    Rate: 1047
    If the access is so difficult that the computer will interfere, you can disconnect, but first the battery.
  • #7 15725981
    znaniecki
    Rate: 22
    This is what it looks like
    • Hyundai i40 1.7 CRDi Fuel Filter Replacement: Step-by-Step Guide & Sequence of Actions DSC_0244.JPG (3.2 MB) You must be logged in to download this attachment.
    • Hyundai i40 1.7 CRDi Fuel Filter Replacement: Step-by-Step Guide & Sequence of Actions DSC_0243.JPG (2.79 MB) You must be logged in to download this attachment.
    rafal_rx
    Help: 56
    Rate: 108
    Five seconds in the google and you have:
    I do not know this engine exactly, but I can see from the photos found on the network that the low pressure pump is together with the toilet pump
To replace the fuel filter in a Hyundai i40 1.7 CRDi, first, access the filter by removing the battery, as it is located beneath it. If the computer obstructs access, it may be disconnected after the battery is removed. The replacement process involves unscrewing the old filter and installing a new one. If the vehicle has a fuel pump in the tank, turn the ignition several times to prime the new filter before starting the engine. In cases where access is limited, the filter may need to be removed from the vehicle for replacement on a workbench. If there is no pump, additional tools and software may be required for venting.
