Creating Electrical Installation Acceptance Report for Tenement House Renovation
12960 12
How do I prepare an electrical installation acceptance report for a renovated flat in a tenement house?
You should have a qualified electrician perform the measurements and issue the report; in practice this means someone with E and D qualification certificates with measurement authorization [#16513174], and if that person cannot write the protocol, you need another electrician who can [#16903601] The report should contain the protocol number, test date, identification of the object and circuit, mains supply system, protection type, standards used, inspection result, measured values, applied protections, measurement methods, instrument data, qualification numbers, signatures, and the final decision plus any remarks or recommendations [#16903601] The acceptance check should include visual inspection and tests such as continuity of conductors, insulation resistance, SELV/PELV or separation, floor and wall resistance, automatic disconnection, supplementary protection, polarity, phase sequence, functional tests, and voltage drop [#16668191] A protocol template exists in the measurement standard, and the report can also be created using dedicated software or a similar pattern [#16514720][#16668191]
  • Need a sample electrical installation acceptance report
    #1 16513147
  • #2 16513174
    Plumpi
    Heating systems specialist
    Help: 874
    Rate: 2674
    The idea is the only one:
    Invite an electrician with the appropriate "authorizations" who will know what to do and issue such a report.
    The "powers" that are required from an electrician are E and D qualification certificates with measurements.
  • #3 16513216
  • #4 16513249
    zbich70
    Help: 1171
    Rate: 6668
    mckalyka wrote:
    I have one, but he says he does not know what to write there ;)
    Change to the one that will be known.
  • #5 16513551
    djlukas
    Help: 94
    Rate: 266
    Do you go to a doctor who does not know how to write a prescription?
  • #6 16513600
    gumisie
    Help: 1667
    Rate: 2485
    Call the Energy Emergency Service, there are people who are authorized and also run a private business. I did it.
  • #8 16613338
    t.kozak90
    Declaration of installation ...
    • 39_Oswiadczenie_o_wykonaniu_malej_instalacji_15.06.2016.pdf (34.05 KB) You must be logged in to download this attachment.
  • #9 16613351
    kozi966
    Help: 599
    Rate: 1288
    And how does it relate to the protocol of measurements, tests and inspections of electrical installations?
  • #10 16667940
    t.kozak90
    This is the same statement. Of course, this does not diminish the fact that the following protocols are required: Inspection, Measurements, Scheme of the installation
  • Acceptance tests required before energizing installation
    #11 16668191
    jann111
    Help: 180
    Rate: 507
    mckalyka wrote:
    According to the guidelines, I renovated a flat in a tenement house
    Did you do this renovation (electrical installation) yourself?
    The person who has given tension to the installation, after it has been made, should issue such a protocol by himself or, if he does not have the appropriate permissions, inform the client about this necessity.
    You should not use this installation without "measurements".
    And what should be found in such a protocol is contained in the "measurement standard" (acceptance check).
    In short: visual inspection as well as tests and tests, which depending on the needs should be carried out in the following order (I quote a standard):
    a) continuity of conductors (see 61.3.2);
    b) insulation resistance of the electrical installation (see 61.3.3);
    c) protection with SELV, PELV or electrical separation (see 61.3.4);
    d) resistance / impedance of floors and walls (see 61.3.5);
    e) automatic power off (see 61.3.6);
    f) subsidiary protection (see 61.3.7);
    g) polarity check (see 61.3.8);
    h) checking the phase sequence (see 61.3.9);
    (i) functional and operational tests (see 61.3.10);
    j) voltage drop (see 61.3.11);
    The protocol can be created by yourself or use dedicated programs.
  • #12 16903114
  • Required contents of an electrical installation acceptance report
    #13 16903601
    Plumpi
    Help: 874
    Rate: 2674
    What kind of help do you expect?
    After all, a colleague of e-sparks told you the standards in which you have the formulas of such a protocol and all the guidelines that should be found in such a protocol and what tests should be carried out. In the net you will also find a number of designs and examples.
    The protocol does not have to look the same, and its appearance is decided by the person who prepares the report.
    Such a report should contain at least:
    - Protocol number
    - Date of testing / protocol.
    - Information identifying the object being tested.
    - Information on the given circuit / electrical point. Sometimes you need to make a drawing and apply your own numbering of circuits / points.
    - Information about the mains supply system.
    - Type of protection used.
    - Information on the standards according to which the tests were carried out.
    - Inspection result.
    - In tabular form: measured values, type / characteristics and values of applied protections, limit values and result if the measured value meets the requirements of the standard.
    - Information on the applied measurement methods.
    - Type and identification data of the measuring instruments used.
    - Identification data and numbers of the qualification certificates of the person performing the measurements
    - Identification data and numbers of the qualification certificates of the person drawing up the report.
    - Signatures of the persons mentioned above.
    - Decision on whether the conditions of protection used and the requirements of the standards are met.
    - Remarks / conclusions / recommendations if the protection is not fulfilled (what should be done to ensure that the protection has been fulfilled or what repair has to be done or what ad hoc measures to remove the threat should be applied, eg disconnecting the circuit from service until repairs etc.)
    At the same time you need to know how to make measurements and what counts.
    In order to be able to issue such a ruling, one must also have access to other standards in which the conditions for the execution of individual measurements and the methods of performing calculations are specified.
    It is really a lot of knowledge, difficult to understand by the first better electrician, and the responsibility is very large.
    Unfortunately, it is impossible to pass on a few lines of fasting, knowledge and experience that must be acquired for years and takes many volumes of documents: laws, regulations, standards and technical knowledge in the field of electrics.
    If your electrician does not know how to write such a protocol, it means that he does not have the appropriate qualifications and knowledge. Therefore, you must find an electrician who not only knows how to write and how to perform the tests, but also has the required by law certificates of qualification Group 1, Maintenance and Exploitation with protective measurements in a specific scope.
To obtain an electrical installation acceptance report for a renovated flat in a tenement house, it is essential to engage a qualified electrician with the necessary E and D qualifications. If the current electrician is unsure of the report's requirements, it is advisable to find one who is knowledgeable. The report must include specific elements such as protocol number, testing date, identification of the object, circuit information, mains supply system details, protection type, applicable standards, inspection results, and measured values in tabular form. The report should adhere to established measurement standards, which outline required tests including continuity of conductors, insulation resistance, and automatic power off checks. Resources for protocol templates can be found in the relevant measurement standards.
