DeWalt - worse in Castorama? - A screwdriver in Casto is cheaper but has a diffe
BundyPL 12168 3
  • #1 16514975
    BundyPL
    Once, by accident, I came across a discussion on the forum about the fact that some products (so generally) for supermarkets are of lower quality. Someone also suggested that they are slightly differently marked. Now I wanted to buy a screwdriver - it was DCD776C2. I also found it on Castorama's website - a lot cheaper - but it turns out that it has the designation DCD776C2-QW.
    And now I don't know if it's the same screwdriver or another. There is no product with such a tip on the producer's website. Can anyone know what QW means in the end?
  • #2 16515490
    Kamilpl123
    Help: 17
    Rate: 42
    Hello, sometimes it is so that the tools that go to supermarkets are "stripped down". So maybe it is in this case or something, I do not know. For example, grinders that normally have a soft start system, in market versions do not have it (such an example).
  • #3 16516767
    BundyPL
    In the end I bought it in Castorama - PLN 568 vs PLN 720 convinced me. I also checked that the screwdriver itself has the same markings as on the manufacturer's website - that is, DCD776. Only on the carton is an additional C2-QW (i.e. DCD776C2-QW together) - this means C2, there are 2 batteries in the package. Unfortunately, they did not write anything which means QW. Well - I count on the fact that the manufacturer would not give a crap because after it breaks down in 2 years I will not say that the Castorama screwdriver just broke, that the DeWalta screwdriver broke. And if such a thing were common then they would take the whole reputation of the brand.
  • #4 16519759
    Jacek1983rr
    Help: 50
    Rate: 367
    On the dewalt website you can extend your warranty for one year and three years for a screwdriver and charger free of charge because the batteries have only one year warranty. You think that you have a two-year warranty, you only have one year, although you are a private user. Personally, as a seller, I think that you chose a model with bad batteries, relatively few sold devices, a lot returned to the complaint after a year of battery life. 2Ah batteries are much better. To extend the life of your batteries, read the instructions for use.
