Comparing Black & Decker bdk188kb-qw and Parkside C3: Prices, Battery, and Warranty
Karwos00 11931 8
  • #1 16931536
    Karwos00
    Rate: 47
    As in the subject - I have the opportunity to buy new ones in a suitcase for PLN 350. For home use - sometimes maybe with a project more often - but without madness.
    Initially, I thought about Parksaid from Lidl - I need a screwdriver and some circular saw with a battery - also for delicate work, whether in the garage, garden, etc. Battery gives more possibilities and is on hand.
    Today in B&W I got this B&D in promotion - once it was a company worth recommending, it's hard to say - opinions are good and bad. The same about the lidl parsaid - one recommends parksida saying that B&D is over. Others that the grocery crap will be worse than any original - but this B&D has little in common with the original.
    Parkside C3 costs about 265 PLN with 1 20v battery. This 2x 18v battery for 350 - that is, practically the cost of 1 battery. Bi b & d is 450. Parkside is PLN 300.
    It's not all about costs but trouble-free use. The warranty is 3 years versus 2 years. In addition, B&D has a stroke - I know it is not a drill stroke, but it probably helps with hollow bricks.
    I know you can buy a blue bosha - but it's more professional equipment that I won't be using fully.
    Thank you for the hints.
    Specification
    the battery can hold over 80% of the charge for over 90 days of stagnation, which means you don't have to charge it just before use.
    The adjustment allows you to choose the speed for your work.
    The torque is also adjustable and offers 11 degrees of adjustment.
    The impact function means that the equipment can handle lighter concrete.
    The maximum drilling diameter in wood and steel is 25 and 10 mm respectively.
    The non-slip, soft handle increases both comfort and safety of use.
    The presence of an additional source of energy in the set gives you the confidence that you can DIY without unnecessary break.
    The set has been packaged in an aesthetic suitcase for easy transport and storage.
    Number of gears 2
    Run right / left yes
    Battery voltage (V) 18
    Battery capacity (mAh) 1500
    Maximum soft / hard torque (Nm) 17/38
    Torque settings 11
    No-load speed (rpm) 0-400 / 0-1350
    Lithium-ion battery type
    Drilling diameter in steel (mm) 10
    Drilling diameter in wood (mm) 25
    Supplied accessories: Plastic case, Batteries x 2
  • Parkside offers larger batteries and broader 20V compatibility
    #2 16932119
    fotzsyzrk
    Rate: 46
    Hello!
    It is a fact that Black & Decker went terribly on dogs, and especially Black + Decker reminded me of the drill that I watched in carrefour was a typical Chinese toy, their old products, sometimes they did not differ from their leading DeWalt brand, to this day I have Dewolt and B&D screwdrivers 9.6V that are still working !! come on, the batteries can barely hold :D .
    In this D + W 1500mAh batteries, in Parkaside 2000mAh, there is also a stroke, personally I would bend to Parkaside, if you are going to buy a saw you will have 2 batteries, gw. 3 years, if something starts to fall, it flies to the service or new and that's it :) I have no idea what else b & d batteries are suitable for but from Lidl there may be products for these 20V PSBSA 20-Li A1 impact drill
    SDS PABH 20 Li B2 rotary hammer
    PABS 20 Li C3 drill driver
    PDSSA 20-Li A1 impact wrench
    Circular saw PHKSA 20-Li A1
    PSTDA 20-Li A1 jigsaw
    Reciprocating saw PSSA 20-Li A1
    PWSA 20-Li A1 angle grinder
    PAMFW 20-Li A1 oscillating multifunction device
  • #3 16932179
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    Black & Decker is trash and hopeless warranty service.
  • #4 16933207
    Karwos00
    Rate: 47
    Change - I asked for a guarantee in Kompernass Service Polska - only products bought in Lidl have a guarantee from them. So those from Allegro may and do have a seller guarantee
  • #5 16943273
    Karwos00
    Rate: 47
    Alright. And what do you think about the GSR 120-Li?
  • #6 16944150
    fotzsyzrk
    Rate: 46
    Cool compact small screwdriver :) can be particularly helpful with this set http://www.narzedzia.pl/wiertarko-wkretarka-z...bxjcyVnvJnzWwkcoImrRGkH25naTHXAcaAoOcEALw_wcB (of course you can buy tips separately)
    In general, these screwdrivers are very cool, I'm going to buy something like this myself, because my screwdriver is ok, but it weighs its DHP458 with a 5Ah battery, with longer work, e.g. with a plasterboard ceiling, it does its job, at some point you can't lift the screwdriver alone, let alone work. The downside of this GSR screwdriver is a small moment, as for the main tool in the "workshop" come on, I don't know what this parkasraid has, because this black + decker is not crazy either.
    My screwdriver is also too unsuitable for work on all kinds of delicate things, they can be quickly damaged, which is why I would need a small screwdriver as a supplement.
    The only question is what do you really need, the batteries work only with these small Bosch devices, so only GKS 12V-26 as something and is rather a precise tool, if you want to accumulate some "family" of devices that works best (the same batteries) then not I know if it will be suitable for CB.
    Personally, I will try to download this set cheaply https://www.cpomilwaukee.com/milwaukee-2494-2...m-ion-3-8-in--drill-driver-and-impact-driver- combo-kit / miln2494-22, default, pd.html
  • #7 16944196
    Karwos00
    Rate: 47
    For me it will be typical home use. Although I plan a little more in the garden, etc. But it will not be 8 hours a day, 6 days a week. Rather, turn up something 10 times a month, unscrew some plasterboard buildings. No drilling holes - for this I have a drill and not a screwdriver :) . Certainly it will happen to drill something - but rather in wood, small drills, or for larger screws.
  • #8 16948542
    fotzsyzrk
    Rate: 46
    You don't need any big torque with drills, unless there are some paddle fi40 etc. or 500mm long, with these larger screws it can be a problem with this screwdriver, with longer screws, it can be hard to get some hardwood dry, in total it's best to use a screwdriver or some impact wrench :) .
  • #9 16948674
    Karwos00
    Rate: 47
    Well, GSR 120-Li at home - I will test and see what I bought - 3 years warranty. 2 years for batteries and charger - better than Parkside with 1 battery without warranty (+3 on equipment). The same price - including 1 battery.
The discussion centers on comparing the Black & Decker BDK188KB-QW and Parkside C3 power tools, focusing on their prices, battery specifications, and warranty terms. The Parkside C3 is priced at approximately PLN 265 with a 20V battery, while the Black & Decker option is available for PLN 350 with two 18V batteries. Users express concerns about the declining quality of Black & Decker products and their warranty service, contrasting it with the Parkside's three-year warranty. The Parkside tools are noted for their higher battery capacity (2000mAh) compared to Black & Decker's (1500mAh). The conversation also touches on the Bosch GSR 120-Li as a potential alternative for home use, highlighting its compact design and three-year warranty, although it has a lower torque rating. Overall, the consensus leans towards Parkside for casual home projects due to its better warranty and battery options.
