Krispol gate Starcus drive - connection of additional lighting
Kristaff 12612 19
How do I connect additional 24 V lighting to a Krispol Starcus 1000 gate drive so it turns on when the gate opens?
Connect the lamp between terminal 4 and GND; that is the lamp output, and it flashes when the gate moves [#17905715][#17904081] If you want additional lighting rather than the built-in flashing lamp output, use a relay or timer driven by the existing light output [#17905715] The output is limited, so use a low-power 24 V bulb such as 10–15 W or an automotive 24 V / 21 W lamp [#16516174][#16516347]
  • #1 16515936
    Kristaff
    Rate: 23
    I have a Krispol Starcus 1000 garage door drive. I would like to connect additional lighting activated when the gate opens. I count on a hint where to connect it. I mean a 24v lamp because I understand that only this can be connected to the above drive.
    In the picture "description" of the connections of the motherboard.
    • Krispol gate Starcus drive - connection of additional lighting 14967736365392141094863.jpg (2.72 MB) You must be logged in to download this attachment.
  • #2 16515997
    nikusert
    Help: 699
    Rate: 1755
    Hello .
    Connect the lamp to the + 24V DC terminal and to terminal 4, which is the last on the strip.
  • #3 16516021
    Kristaff
    Rate: 23
    And this is where the problem arises. I thought exactly the same as the only logical option and none of that. I connected to output 24 and to the last one called lamp and nothing. Zero reaction :-(
    I connected the meter to these terminals and no voltage appears on them when the gate is activated.
  • #4 16516050
    nikusert
    Help: 699
    Rate: 1755
    What does the display show? It should show 99-11 after turning on the power
  • #5 16516067
    Kristaff
    Rate: 23
    The gate display is 2 digits and when activated it shows OP or CL. Open close is known. Nothing more.
    After power off and on again, it actually displays a countdown from 99 to 11
  • #6 16516082
    nikusert
    Help: 699
    Rate: 1755
    As the display shows in position (3) of programming, according to the instructions.
  • #7 16516100
    Kristaff
    Rate: 23
    After turning on the power, i.e. position 3, the display shows 99-11 and the lamp actually lights up, but only the built-in one, i.e. 3 diodes. This connected as an additional one under the 24v terminals and the lamp does not respond.
  • #8 16516132
    nikusert
    Help: 699
    Rate: 1755
    Which lamp or bulb you have connected to this output. Strange because nothing is written about this output. Check the fuses, if you have a light bulb or a LED lamp connected, then polarization is important.
  • #9 16516146
    Kristaff
    Rate: 23
    For a quick I connected a 24v light bulb in a building socket. I connected the cables in both ways.
    • Krispol gate Starcus drive - connection of additional lighting 1496777896251145647242.jpg (1.45 MB) You must be logged in to download this attachment.
  • #10 16516174
    nikusert
    Help: 699
    Rate: 1755
    To such 24V outputs connect a 15W max 60W bulb. The output may have limited power, which is different when the output is 230V. Check with the meter if there is any voltage.
  • #12 16516190
    Kristaff
    Rate: 23
    A voltage of 0.1v appears on the meter
    There is a voltage of 25.2 between gnd and 4
  • #13 16516199
    nikusert
    Help: 699
    Rate: 1755
    You would have to trace from where this output is powered, whether through a relay (maybe burned contacts), or another electronic component.
  • #14 16516214
    Kristaff
    Rate: 23
    Nikusert - virtually new maiden drive nothing combined.
    Sosarek - voltage on gnd and 4 (lamp) is still there.
    Added after 28 [minutes]:
    I connected the lamp to the 4-lamp terminals and gnd actually lit up when the gate was activated and shone. The built-in lamps went out and the additional lamp was still lit. It went out a minute after the built-in but ...
    It went out because everything was massacred and the drive dumped something like the picture.
    • Krispol gate Starcus drive - connection of additional lighting 14967808298071338632366.jpg (565.46 KB) You must be logged in to download this attachment.
  • #15 16516347
    nikusert
    Help: 699
    Rate: 1755
    So how is it with voltage metal, once you specify it is 0V, once 25V? Best connect a bulb with a lower power, as I wrote. It can be automotive 24V / 21W, or there are additional 24V / 10-15W with a small thread in electrical wholesalers. If there is voltage, maybe there is a problem in the socket (check), or the bulb itself to check. Check if there is voltage light bulb or replacement of the moment does not disappear. If it disappears, it may indicate that the output to the lamp is overloaded. The manual does not contain power, but usually there should be a weak light bulb due to the limited power of the transformer.
  • #16 16516373
    Kristaff
    Rate: 23
    Once gives 0v and once 25v because I connect to different sockets. 0 I have a 24v connection - a lamp. 25v appears on the connection lamp (4) -gnd. Tomorrow he'll try to connect a car light bulb. I have access to such at work.
  • #17 16516400
    nikusert
    Help: 699
    Rate: 1755
    It is difficult at the moment to say what it is, whether a transistor or something else. The fact that this element was thought, it is confirmed by the eyes I wrote. Is this element at the output to the lamp? Check with the meter what it shows.
  • #18 16516427
    Marek J.
    Help: 526
    Rate: 951
    Kristaff wrote:
    drive virtually new virgin nothing combined.
    ... was until you connected the too big bulb.
    PNP bipolar transistor has fallen
    You need to buy, solder and if nothing else was done next attempts through a 24V relay.
    Ot and all.
  • #19 17904081
    Stugraj
    For me a similar problem, when connecting + 24V DC and 4 the lamp is off, while as connection GND and + 24V DC it is constantly lit, while when connecting GND and 4 (flasch) it blinks when lifting / lowering the gate.
  • #20 17905715
    nikusert
    Help: 699
    Rate: 1755
    Yes, according to the instructions 4 and GND, but it will flash. You can add a timer and control the additional lighting, or connect the appropriate relay (for the correct voltage) to the existing lighting in the drive. Then you can use any lamp of any power.
The discussion revolves around connecting additional lighting to a Krispol Starcus 1000 garage door drive. The user seeks guidance on connecting a 24V lamp that activates when the gate opens. Initial suggestions include connecting the lamp to the +24V DC terminal and terminal 4, but the user reports no voltage at these terminals when the gate is activated. Subsequent troubleshooting reveals fluctuating voltage readings and issues with the connected lamp. Participants suggest checking the bulb's power rating, potential relay issues, and the possibility of a damaged transistor due to overloading. Solutions include using a lower wattage bulb or a relay to control the lighting effectively.
