Ford Fiesta 2005 Mk6 Diesel 1.6L Engine: Selecting Used Electric-Hydraulic Power Steering Pump
jacekmonter 6597 11
How do I choose a used electric-hydraulic power steering pump for a 2005 Ford Fiesta Mk6 1.6 diesel: by car model/engine or by the pump number?
Choose the pump by its exact number or verify it with the VIN, not only by the car model and engine. If the number is not visible on the old pump, call the seller and give them the VIN so they can match the correct unit [#16517324] You can also connect the car to diagnostics and read the pump controller number if it is still alive [#16517462] Another option is to open the pump and check the sticker inside, where the number is on the board [#16517462]
  • #1 16517174
    jacekmonter
    Hello, I am new and I am looking for someone wise to advise me, namely the power steering pump that has failed me. I cannot afford a new one and I want to buy a used one. Can I follow the car model and engine power or do I need the pump number? I would like to add that the pump for electric-hydraulic power steering, auto Ford fiesta 2005, Mk6, diesel, 1.6 engine. I wanted to order from Allegro but there is so much there that I have doubts myself. I don't know if I can read the number from the old pump.
  • #2 16517324
    Foxtrott
    Help: 253
    Rate: 944
    When you do not have the number visible, it is best to call the seller (have VIN prepared) to present the case and he will certainly help you choose the right pump.
  • #3 16517462
    panstalin2
    Help: 30
    Rate: 216
    Connect the car to the computer and log in to the pump controller, if it is alive, it will be there to read the pump number.
    You can disassemble the pump and there will be a sticker inside with the number on the motherboard - unless you replace the transistors and repair the pump.
  • Do not drive with a failing power steering pump
    #4 16517900
    jacekmonter
    I have already talked to one electromechanic and the pump will be dismantled, he will order and he will do it. I am worried about this number because when there was a regular card, I do not know if there was anything left of it. with AC and about 4 months ago the power steering started to go crazy once it worked once not, as it turned out the pump was stuck with tape, they did not put a new one. Is it possible to drive somewhere before this pump comes, or is it better not to move the car?
  • Advice to avoid driving with failed power steering pump
    #5 16518180
    g107r
    Help: 811
    Rate: 993
    jacekmonter wrote:
    And the question is, is it possible to drive somewhere before this pump comes, or is it better not to move the car?
    jacekmonter wrote:
    about 4 months ago, the support started to go crazy once it worked, once it did not
    And how was it ? Heart stopped on the shoulder, no way to turn without assistance, and stuff like that?
    If you got used to driving without power steering, you might. Oh yes? You will drive into a tree or into people ...
    It works toto at all, how do you remove the fuse or plugs from the pump?
    By the way, you are looking at auctions, sometimes people think that they know what they are selling and what about other stores? http://e-katalog.intercars.com.pl/#/ekatalog/osobowe/towary/18329/803010000/
  • #7 16518396
    panstalin2
    Help: 30
    Rate: 216
    There is to be a sticker inside the pump with the number on the chip.
    If you have strength in your hands, you can go without assistance - it is uncomfortable to maneuver with the trailer.
  • #8 16549930
    jacekmonter
    Listen, I have a problem with the pump again, the pump bought according to the number, the electromechanic connected, the fluid was replaced with a new one, and today the power steering does not work again. I ask what's going on? Everything was ok, it was running smoothly, does anyone have any idea ??????
  • #9 16550042
    panstalin2
    Help: 30
    Rate: 216
    Log in to the pump controller which errors it lists, check the pump power supply, whether the connection has overheated at the fuses.
    Check the correctness of the readings from the steering column angle sensor.
  • #10 16552888
    jacekmonter
    I do not know what the problem is, but when I got into the car later, everything worked and it is ok today, and even one more after driving a section and parking something started to squeak, I do not know how to describe it, it is such a pulling sound uuuuuuu :) Later it stopped, it was Sunday so I gave up, today nothing squeaks and everything works. I thought that maybe it was because of yesterday's rain because it was pouring terribly and maybe it washed my wires or something, I don't know. Go where they did a mythical pump or maybe I can watch some time what's next ???
  • #11 16553158
    panstalin2
    Help: 30
    Rate: 216
    Check the alternator belt - replace, the pump needs a lot of electricity.
  • #12 16585537
    jacekmonter
    Well, it broke again, the pump did not work, no power steering, I was driving the car on the road, something started to squeak and I could hear uneven work under the hood, something gurgled and made puuuffffffffff and that's it. I couldn't stop. I called the electromechanic where they put the pump on and says that you have to buy a completely new one because it was used and that's why it broke, this is the 3rd power steering pump and always the same problem. Help people, what could be wrong ??????
The discussion revolves around selecting a used electric-hydraulic power steering pump for a 2005 Ford Fiesta Mk6 with a 1.6L diesel engine. The user seeks advice on whether to rely on the car model and engine specifications or the pump number for compatibility. Suggestions include contacting sellers with the vehicle identification number (VIN) for assistance, checking the pump controller for the pump number, and inspecting the old pump for a sticker with the number. Concerns about driving the vehicle without power steering and the reliability of used pumps from online sources like Allegro are also raised. After purchasing a used pump, the user experiences recurring issues, prompting discussions about potential electrical problems, the need for a new pump, and the importance of checking the alternator belt.
