Ford focus 1.8 tdci 2002 - Replacement of the delphi injection pump
Hobbysta76 34458 13
Do I need to remove or loosen the timing chain to take out the Delphi injection pump on a 2002 Ford Focus 1.8 TDCi?
No, the timing chain does not need to be removed to take out the pump. You only need to loosen the chain tensioner/bracket behind the engine, but not remove it; move the bracket away after undoing its three nuts [#16207734] [#16209416] There is a key screw between the block and the bracket, probably 19 mm, which you loosen until the chain is no longer tensioned [#16209416] In the end, the pump can come out without loosening the timing chain [#16240693]
  • #1 16207650
    Hobbysta76
    Rate: 47
    Hello, I have a question - is it necessary to pull the chain to pull the pump out?
  • #2 16207734
    Daro122
    Help: 165
    Rate: 751
    All you need to do is loosen the chain tensioner, but it's still a bit of work.
  • #3 16208759
    Hobbysta76
    Rate: 47
    And some simple way to block the shaft because to unscrew the chain of the chain on the pump would probably block the shaft.
    And where is the hole to block the shaft.
  • #4 16208990
    m789
    Help: 23
    Rate: 56
    Here is everything shown and lots of useful information link
    Pump disassembly link assembly link
  • #5 16209088
    Hobbysta76
    Rate: 47
    And you really need to loosen the tensioner and then you need to unscrew the lid of the chain and surely drain the engine oil?
  • #6 16209416
    Daro122
    Help: 165
    Rate: 751
    You unscrew the bracket with the tensioner behind the motor three nuts you do not have to remove it, just move away. Between the block and the bracket is a key screw probably 19, just loosen it until it stops tensioning, the chain does not have to be removed.
  • #7 16210061
  • #8 16210392
    Hobbysta76
    Rate: 47
    The pump showered the filings as there were these cold frosts, plugged in the injections, were cleaned, ignited, walked for 15 seconds, started to stop and that's all after smoking. They will clean up the price again, but I want to check the pump in the middle, how it's powdered again, something inside is happening to her. I pulled it out, I'll take injections tomorrow.
  • #9 16210407
    osimus
    Replace the fuel filter and the pump supply lines for cleaning.
  • #10 16210417
    Hobbysta76
    Rate: 47
    The filter replaced after a breakdown, the wires also give for cleaning.
  • #11 16210425
    osimus
    Yes, but the filter could get the filings again, I suggest to change again.
  • #12 16210622
  • #13 16215478
    osimus
    Good additives for fuels and oils is liqui moly German means and many injections have already begun. The Transit colleague is right about the delphi system you have to take care of more than others because the parts fall faster at lower mileage.
  • #14 16240693
    Hobbysta76
    Rate: 47
    Hello after the break, the pump showered filings from the pump system, new parts, injectors cleaned, the pump checked, and probably enough fire in the subject. And you do not have to loosen the timing chain, the pump comes in without a problem.
The discussion revolves around the replacement of the Delphi injection pump in a 2002 Ford Focus 1.8 TDCi. Users clarify that it is not necessary to remove the timing chain to extract the pump; instead, loosening the chain tensioner is sufficient. Some participants discuss the need to block the shaft to prevent it from rotating while unscrewing the chain. Concerns about potential issues leading to pump removal, such as filings in the system and low fuel pressure, are also addressed. Recommendations include replacing the fuel filter and using fuel additives to maintain pump health, as Delphi components are noted for their delicacy and tendency to fail at lower mileages.
