Samsung S6 EDGE G925F - When you close the case, the screen will go blank and th
Fu-Fu 6321 1
  • Hall sensor likely causing flip-cover touch freeze
    #1 16518472
    Fu-Fu
    Help: 9
    Rate: 110
    Hello!
    Samsung S6 EDGE and the original Samsung case with a flip - when I close the case the screen will go blank normally, but if I open the flip then the touch is frozen, the buttons work.
    Apparently it happened after installing Android 7, I uploaded the latest soft from ANDROID 6.0.1 support, but it's still the same.
    Is it possible to upload older soft? As I try it Z3X crashes error
    File analysis ... Ok
    Total file size: 0x126738FD4 (4711 Mb)
    Searching USB Flash interface ... COM36 detected
    Setup connection ... Approx
    Set PIT file ... Approx
    Reading PIT from phone ... Approx
    Sending sboot.bin ... error timeout
    Done with Samsung Tool PRO v.28.2
    Rather, I suspect that something will be with the sensor.
  • #2 16520610
    meaverick
    Help: 109
    Rate: 242
    do not upload anything, go to SETTINGS find DISPLAY and in the options find the wake up function, there will be several options to choose from. The rest will be easy.
    best regards
